29393 Discussions
GENERIC for Type-bound Procedure causes error #6632 When Calling Subroutine with Keyword Argument
reubendb
It seems that there is a bug with GENERIC implementation for type-bound procedure. I am trying out the latest Intel Fortran Compiler on linux. When calling a GENERIC subroutine (with type-bound procedure) with Keyword argument, the compiler complains that I don't have an explicit interface, although the subroutine is in a module. Here is a test case.
Suppose I have the module file: VG_Mofule.f90:
[fortran]module VG_Module
  implicit none
  private
  type, public :: VGForm
    integer  :: dummy
  contains
    procedure, pass :: I_Alloc
    procedure, pass :: I_Assoc
    generic :: Init => I_Alloc, I_Assoc
  end type VGForm
contains
  subroutine I_Alloc ( VG, V, ClearOption )
    class ( VGForm ), intent ( inout ) :: VG
    integer, intent ( in ) :: V
    logical, intent ( in ), optional :: ClearOption
    print*, 'I_Alloc subroutine', V
    if ( present ( ClearOption ) ) print*, 'Is Clear?', ClearOption
  end subroutine I_Alloc
  subroutine I_Assoc ( VG, V, ClearOption )
    real, dimension ( : ), intent ( in ), target :: V
    print*, 'I_Assoc subroutine', V
  end subroutine I_Assoc
end module VG_Module
[/fortran]
And the corresponding test program: VG_Test.f90
[fortran]program VG_Test
  use VG_Module
  implicit none
  type ( VGForm ) :: VG_1, VG_2, VG_3, VG_4
  call VG_1 % Init ( 1 )
  call VG_2 % Init ( [ 3., 4., 5.] )
  call VG_3 % Init ( 3, ClearOption = .true. ) !-- This call produces error
  call VG_4 % I_Alloc ( 4, ClearOption = .true. )
end program VG_Test[/fortran]
If I compile these, I get:
[bash]$ ifort -c VG_Module.f90
$ ifort -o VG_Test VG_Test.f90 VG_Module.o
VG_Test.f90(13): error #6632: Keyword arguments are invalid without an explicit interface.   [CLEAROPTION]
compilation aborted for VG_Test.f90 (code 1)
$ ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0 Build 20110309
Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
[/bash]
These files compile without error with the latest gfortran and Cray fortran compiler.
Thanks - this is a problem that our developers are already working on. The issue ID is DPD200166645.
This will be fixed in a future version of the compiler.
reubendb
The latest release (2011.4.191) still has this isse :(. Any ETA for the fix ?
$>ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0 Build 20110427
It will be some months out. Sorry for the inconvenience, but it was a complex fix which requires more testing than what normally goes into an update. If this is seriously impacting you, let me know and we may be able to help.
FlyingHermes
What is the status of this bug ?
It seems to be still present in ifort version 13.1.1.
Am I right ?
The bug reported in the original posting is fixed - it compiles fine with 13.1.1. You may have a source that gets the same error message for a different cause. Please provide an example that shows the problem you're seeing.
FlyingHermes
By reducing the code that produced an erronious output, I've found that the error was indeed not related to the bug descibed in the current post.
I've created a new topic, "Bug using an array of derived-type with an polymorphic component" (http://software.intel.com/en-us/forums/topic/392803)
