GETEXCEPTIONPTRSQQ returns NULL
irhan__baris
Dear All,
I implemented an exception handler and registered it with SIGNALQQ. Within this exception handler I want to call TRACEBACKQQ function with EPTR option. Unfortunately GETEXCEPTIONPTRSQQ() function returns NULL. Does anyone of you have an idea why? Thank you for your time in advance.
Baris Irhan,
integer(4) function h_fpe (signum,ecode)
!DIR$ ATTRIBUTES C :: h_fpe
!params
integer(2) :: signum
integer(2) :: ecode
!variables
integer(4) :: RTN_STS
integer(KIND=INT_PTR_KIND()) :: EPTRS
include 'FOR_IOSDEF.FOR'
!body
!write(*,'(/,A)') 'in signal handler for sig$fpe'
!write(*,*) 'signum = ', signum
!write(*,*) 'ecode = ', ecode
!read(*,*)
EPTRS = GETEXCEPTIONPTRSQQ()
call TRACEBACKQQ(USER_EXIT_CODE=-1,STATUS=RTN_STS,EPTR=EPTRS)
if (RTN_STS .EQ. FOR$IOS_SUCCESS) then
write(*,*) 'TRACEBACK WAS SUCCESSFUL'
read(*,*)
end if
h_fpe = 1
end
Lorri_M_Intel
I would try adding USE IFCORE to your program so that GetExceptionPtrsQQ is properly defined.
It's possible that the return value is being interpreted as a REAL, being converted to INTEGER before being stored in EPTRS, and weird things are happening.
               I hope this helps --
                                    --Lorri
irhan__baris
Dear Lorri,
I defined event handler as a module procedure. use IFCORE has already been added at module declaration...
irhan__baris
Dear Colleques,
I am still NOT able to figure out why GETEXCEPTIONPTRSQQ function returns NULL when it is called within exception handler. Why I am not able to use this nice feature...
