GUID
JohnNichols
Valued Contributor III
Dear Steve:
In the WINDOWS API and using C there is a complicated procedure to create a GUID, but in FORTRAN it appears to be a bit simpler. Can you confirm that the following code creates GUID's for use in Fortran?
[bash]TYPE T_GUID
     SEQUENCE
       integer(ULONG) Data1 ! knowns  unsigned long
       integer(USHORT) Data2 ! knowns  unsigned short
       integer(USHORT) Data3 ! knowns  unsigned short
!DEC$ IF DEFINED(__KEEP_OLD_CHARACTER_ARRAYS)
       character(UCHAR) Data4(8) ! knowns  unsigned char
!DEC$ ELSE
       character(8) Data4
!DEC$ ENDIF
     END TYPE[/bash]
Steven_L_Intel1
"Fortran" doesn't know what a GUID is. You are creating a value that is passed to some procedure, most likely a Windows API routine. These typically want a 128 bit value. Many of the provided interfaces to these routines have arguments with a declared T_GUID type or something similar. You would need to look at the declaration of the routine to see which type it takes.
The declaration you post above, from IFWINTY, is a literal translation of a C declaration. It works, but is not necessarily the only way to create a GUID. The interesting part is that a GUID is usually represented as a 32-bit hex value, followed by three 16-bit hex values, followed by a 48-bit hex value. The type abpve doesn't really reflect that division, but as there are no 48-bit types in Fortran (or in C), it's as good a choice as any.
So that is the derived type structure. How you fill in the values is another thing, and yes, it can be messy. If I was doing this a lot I might write a function to do it to which I pass the usual string-form of a GUID.
jimdempseyatthecove
The above is a data layout for the GUID not the generator.
See: http://en.wikipedia.org/wiki/Universally_unique_identifier
for some background information.
JohnNichols
Dear Steve and Jim:
But my interest is only in two USB devices, both with unique GUID's that make a straigh declaration messy, but quick. At the moment I am just learning how to put it all together, so messy is fine. I think I have made a tolerable guess at the variable types and creating an interface to the SetupDiGetClassDevs, but when I link the linker can not find the SetupDiGetClassDevs in the SETUPAPI.lib. I included the library with the list of source files but this gives me a LNK2019 error. How do I link the lib in?
[bash]IntA = SetupDIGetClassDevs(USBOSR, Enums, hWNDP, INTD)[/bash]
Steven_L_Intel1
It's not "how do I link the lib in", but rather, "How do I declare this properly in Fortran? Looking at MSDN I'd guess it might be something like this:
[bash]interface
  function SetupDiGetClassDevs (ClassGUID, Enumerator, hwndParent, Flags)
  !DEC$ ATTRIBUTES STDCALL, DECORATE, ALIAS:"SetupDiGetClassDevs" :: SetupDiGetClassDevs
  use ifwinty
  integer(HANDLE) :: SetupDiGetClassDevs ! Function return value
  type (T_GUID), intent(in), optional :: ClassGUID
  !DEC$ ATTRIBUTES REFERENCE :: ClassGUID
  character(*), intent(in), optional :: Enumerator
  !DEC$ ATTRIBUTES REFERENCE :: Enumerator
  integer(HANDLE), intent(in), optional :: hwndParent
  integer(DWORD), intent(in) :: Flags
  end function SetupDiGetClassDevs
end interface[/bash]
JohnNichols
Dear Steve:
I am having problem with the enumerator variable, the compiler does not like it, complains with a error #6832.
The other interesting feature is when I load the SLN file, MS Studio throws an exception message.
I enclose the entire directory as an attachment, as you might care to look at the exception message.
I am lost on the 6832 error.
I also got warnings on the optional flags, so I took them out.
Could you have a look at the program and tell me what mistake I ma making in trying to link to the C routine.
JMN
Steven_L_Intel1
You cannot declare a local variable to be CHARACTER(*). You might choose CHARACTER(80) for EnumSA. But when MSDN says "set Enumerator to NULL" it doesn't mean the string "NULL" - it means the value NULL (0).
Yes, the OPTIONAL attributes I suggested don't work here. Use this instead:
[fortran]    interface
            use ifwinty
            type (GUID), intent(in) :: ClassGUID
            !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: ClassGUID
            character(*), intent(in):: Enumerator
            !DEC$ ATTRIBUTES REFERENCE, ALLOW_NULL :: Enumerator
            integer(HANDLE), intent(in) :: hwndParent
            !DEC$ ATTRIBUTES ALLOW_NULL :: hwndParent
    end interface[/fortran]
and change the call to:
IntA = SetupDIGetClassDevs(USBOSR, NULL, NULL, INTD)
See how that works for you.
JohnNichols
Steve:
No that did not fix it, I dug out my Fortran 95/2003 Explained Book from my bookcase, the bookcasenearest the beer and my comfortable chair. Anne only lets me keep a few books beside the comfy chair.
The C Routine has the first argument as a C pointer to the GUID, as far as my limited understanding of interfaces goes we are actually passing or attempting to pass the type(GUID), do we not need a pointer to a GUID, a c_ptr type?
Now that is way beyond anything I have done before.
Just a thought.
JMN
Steven_L_Intel1
No, the interface I provided has the GUID passed by reference, which is what it wants.
