Generate bmp or jpg image file
zxu4
I want to generate an image file to display my output.
I have an array of numerical data and want to put them on different location of the image. There will be lines to connect each numerical values in the picture. Something like a tree.
Any advices are welcome!
Thanks!
Roy
onkelhotte
New Contributor II
Hi Roy,
you can save images with the "saveimage" routine. Just make sure you have activated the right window.
Markus
royxu
Can I use saveimage subroutine in the Linux environment?
Thanks!
Roy
SAVEIMAGE is a QuickWim routine and doesn't do what you want (and isn't on Linux).
I'd suggest looking at the PGPLOT graphics library.
