29651 Discussions
Generating 64bit code on x86_64 Linux machine...how?
elazarus
On our Linux cluster, the "arch" command returns x86_64; however the Intel Fortran compiler is generating 32 bit code. The only compiler option for 64 bits is '-m64' and that option is not available. What gives?
earl
TimP
Quoting - elazarus
earl
You are entitled to install both the 32-bit and the 64-bit ifort, on an x86_64 system. You choose between them by running the environment variable script, appending the intel64 option for 64-bit in the current version, or by running the script in the /fce/ rather than the /fc/ installation directory on the past versions. The -m32 and -m64 options aren't implemented in ifort, although of course you must use them consistently for gcc when combining gcc and ifort code.
