Generic Statement
marat_a
I'm trying to use features of fortran 2003.
Problem is procedure bound to type.
I'm want my method "init" have couple of implementions
So I've tried to use "GENERIC" statement.
file_handler_module.f90(24): error #5082: Syntax error, found '::' when expecting one of: ( % : . = =>
generic :: init=> init_d,init_e
file_handler_module.f90(24): error #6592: This symbol must be a defined parameter, an enumerator, or an argument of an inquiry function that evaluates to a compile-time constant. [INIT_D]
file_handler_module.f90(24): error #6973: This is not a valid initialization expression. [INIT_D]
file_handler_module.f90(50): error #6645: The name of the module procedure conflicts with a name in the encompassing scoping unit. [INIT_D]
subroutine init_d(f,name_prefix)
file_handler_module.f90(24): error #6404: This name does not have a type, and must have an explicit type. [INIT_D]
compilation aborted for file_handler_module.f90 (code 1)
code
[bash]module file_handler_module
IMPLICIT NONE
    type cfile_handler
         private
        character*55 ::file_name
        integer::file_handle
    contains
!         procedure :: init
        procedure :: handle
        procedure :: name
    end type cfile_handler
    private current_handle
    integer::current_handle=1000!
    contains
        class (cfile_handler)::f
        character*25 ,intent(in) ::name_prefix
    end subroutine init_d
    subroutine init_e(f,name_prefix,name_ext)
        character*25 ,intent(in) ::name_ext
    end subroutine init_e
    integer function handle(f)
        handle=f%file_handle
    end function handle
    character*55 function name(f)
        name=f%file_name
    end function name
end module file_handler_module
[/bash]
Question: what's wrong?
is generic statement is supported?
Is there some other wayto do it?
John4
Valued Contributor I
In the latest Release Notes there's a note for it:
Note: GENERIC attribute, FINAL procedures and type-bound operators are not supported in this release
mecej4 is right about the required specific binding. gfortran (v4.5) complains about it:
Error: Undefined specific binding 'init_e' as target of GENERIC 'init' at (1)
mecej4
I believe that you need to declare init_d and init_e as type-bound procedures before defining the generic name init on line-14.
Be that as it may, I don't think that the Intel Fortran compiler supports generic type-bound procedures yet (this statement is a candidate for correction if the Intel people comment on it).
John4
marat_a
Thanks You Guys!
Now it's all clear. I hope generic statement will be included soon.
Yes, it will be in a release later this year.
marat_a
Great news! I'm loooking forward to it.
