Generic interface for repeat
ender01
Hello all,
I've defined a new type, foo:
[cpp]type foo
   integer(kind=1) :: size
   character(len=1), dimension(:), allocatable:: token
end type foo[/cpp]
I've overloaded the cat operator (//) to perform concatenation of two foo objects and now want to supply a generic interface to a repeat function foo_repeat:
[cpp]pure function foo_repeat(foo_var,n_copies) result(new_fooVar)
   type(symbol), intent(in)  :: foo_var
   integer(kind=I_LO), intent(in) :: n_copies
   type(symbol) :: new_fooVar
   integer(kind=I_LO) :: kount
   !  Copy base_Symbol into new new_Symbol
   new_fooVar = foo_Var
   !  Loop over new_Symbol (n_copies - 1) times concatenating new
   !  copies of base_Symbol each time (first copy made above)
   do kount = 2,n_copies
      new_fooVar = new_fooVar//foo_Var
   end do
end function foo_repeat[/cpp]
I tested it and it worked fine;
[cpp]subroutine test_foo_repeat
   implicit none
   type(foo):: test_Foo, test_RepeatFoo
   test_Foo = foo(2,["1", "4"])
   test_RepeatFoo = foo_repeat(test_Foo,3)
end subroutine test_foo_repeat[/cpp]
Then I decided to define a generic interface overloading repeat:
[cpp]module foo_bar
   implicit none
   private
   public :: foo, operator(//),..., repeat, ....
   interface repeat
      module procedure foo_repeat
   end interface
   contains
      pure function foo_repeat...
end module foo_bar[/cpp]
Now when I replace foo_repeat with repeat in the test code above and compile the code I get the error #6362: The data types of the argument(s) are invalid. [REPEAT].
What's going on?
Rich
I figured out what was going on here.
1. You have a bug in your code. The call to repeat passes the literal 2 as the second argument, which is default integer, but your specific procedure foo_repeat declares this argument as integer(I_LO), which is integer(2). Therefore there is no match for the generic. If you say 2_I_LO it works.
2. The reason the explicit call to foo_repeat works is that we have an extension where if you have a numeric literal as an actual argument and you are calling a non-generic procedure which declares that argument as having a different KIND, we will helpfully convert it for you. If you turn on standards checking you'll get a warning about this.
3. The compiler is giving a confusing error message because you're calling a name of an intrinsic If it wasn't an intrinsic, say, xrepeat, then you'd get a more useful message about being unable to resolve the generic. But since it is the name of a generic, you get an unhelpful message saying the arguments don't match. I will suggest to the developers that in the case of a user-overloaded intrinsic generic that the more generic (!) message be given in this circumstance.
You've omitted so much it's hard to reconstruct what you might have done. I tried to fill in the blanks as best as I could and it compiled fine. My guess is that at the point you use REPEAT that your declaration of the generic REPEAT is not visible. Therefore you get the Fortran standard intrinsic REPEAT which takes different argument types from what you had. If you had properly extended the generic, it would work.
Here's my test version.
[cpp]module test
   implicit none
  ! private
   !public :: foo, operator(//),..., repeat, ....
   interface repeat
   end interface
   type foo
   integer a
   integer, dimension(2) :: b
   end type foo
   integer, parameter :: I_LO = 4
   contains
   type(foo), intent(in)  :: foo_var
   type(foo) :: new_fooVar
      !new_fooVar = new_fooVar//foo_Var
   end do
end module test
   use test
   implicit none
   !test_Foo = foo(2,["1", "4"])
ender01
[cpp]module test
implicit none
! private
interface repeat
end interface
type foo
integer a
end type foo
contains
end do
end module test
use test
implicit none
Hi Steve,
Thanks for the effort, I'm sorry that I wasn't clear. The problem that I'm having is that I'm trying to invoke foo_repeat via the generic interface repeat (the line in subroutine test_foo_repeat would then be:
test_RepeatFoo = repeat(test_Foo,3)
If I get make foo_repeat public and use the explicit interface, the function works. Here is the actual code, mutatis mutandis:
[cpp]!*******************************************************************************
!  Module:  foo        *
!  Purpose: Creates the foo object. The object captures a lexical token in the *
!           form of a character array.                                         *
!	Dependencies:    N/A                                                   *
!  Notes:   N/A        *
!  Version:	1.0	Base implementation			07 Nov. 2008   *
!  References:        *
module foo_Mod
   implicit none
   private
   public :: foo, assignment(=), len, operator(//), repeat
   !  Precision constants
   integer, parameter:: HI=selected_real_kind(12)
   integer, parameter:: LO=selected_real_kind(5)
   integer, parameter:: I_HI=selected_int_kind(9)
   integer, parameter:: I_LO=selected_int_kind(4)
   !  Define foo object
   type foo
      integer(kind=I_LO) :: size
      character(len=1), dimension(:), allocatable :: token
   end type foo
   !  Define assignment interface
   interface assignment(=)
      module procedure set_Token
      module procedure get_Token
   end interface
   !  Define operator interfaces
   interface operator(//)
      module procedure cat_Foo
   end interface
   !  Define generic interface for repeat and len functions
   interface repeat
   end interface
   interface len
      module procedure get_Size
   end interface
   !  Define module procedures
   contains
      !                        Object Manipulation                           *
      !  Subroutine:  set_Token                                              *
      !  Purpose: Sets the lexical token associated with foo object from an  *
      !           input character string.                                    *
      !  Dependencies:    len (get_Size)                                     *
      !  Arguments:    foo_var   -  Foo object to which token is to be       *
      !                                assigned                              *
      !                new_Token    -  Lexical token to be assigned          *
      !  References:                                                         *
      subroutine set_Token(foo_var,new_Token)
	 type(foo), intent(inout)  :: foo_var
	 character(len=*), intent(in) :: new_Token
	 integer(kind=I_LO) :: kount, new_Size
	 logical :: alloc_Flag
	 !  Get length of new token
         new_Size = len(new_Token)
	 !  As this may be a redefinition of the symbol check allocation
         !  status and set alloc_Flag to true if token must be allocated
         alloc_Flag = .not. allocated(foo_var%token)
         !  Test that any allocation is appropriate
         if (.not. alloc_Flag) then
            !  Token has already been allocated, is it the right size
            alloc_Flag = len(foo_var) /= new_Size
            !  If token has the wrong size, deallocate
            if (alloc_Flag) then
               deallocate(foo_var%token)
            end if
         end if
         !  If necessary, resize and allocate storage array
            foo_var%size = new_Size
            allocate(foo_var%token(new_Size))
         end if
         !  Assign new token to foo_var object
         do kount = 1,len(foo_var)
            foo_var%token(kount) = new_Token(kount:kount)
         end do
      end subroutine set_Token
      !  Function:  cat_Foo                                                  *
      !  Purpose: Concatenates symbols.                                      *
      !  Arguments:    foo_var1   -  Foo object to which additional foo      *
      !                              object is to be concatenated            *
      !                foo_var2   -  Foo object to be concatenated to a base *
      !                              foo object                              *
      !  Returns:       new_foo   -  New symbol formed by concatenation      *
      !  Version:	1.0	Base implementation	     08 Nov. 2008    *
      !  References:                                                         *
      pure function cat_Foo(foo_var1,foo_var2)  result(new_foo)
	 type(foo), intent(in)  :: foo_var1, foo_var2
         new_Size = len(foo_var1) + len(foo_var2)
         !  As this may be a redefinition of the foo object check
         !  allocation status
         alloc_Flag = .not. allocated(new_foo%token)
            !  Token has already been allocated, is it the right size?
            alloc_Flag = len(new_foo) /= new_Size
               deallocate(new_foo%token)
            end if
         end if
            new_foo%size = new_Size
            allocate(new_foo%token(new_foo%size))
         end if
         !  Assign new token to new symbol object
         new_foo%token(:len(foo_var1)) = foo_var1%token(:)
         new_foo%token(len(foo_var1)+1:) = foo_var2%token(:)
      end function cat_Foo
      !  Function:  foo_repeat                                               *
      !                   // (cat_Foo)                                       *
      !  Arguments:    foo_var    -    Foo object to which additional copies *
      !                                are to be concatenated                *
      !                n_copies   -    Number of copies of foo object to be  *
      !                                concatenated                          *
      !  Returns:       new_foo   -   New foo object formed by concatenation *
      !  Version:	1.0	Base implementation		10 Nov. 2008 *
      !  References:                                                         *
      pure function foo_repeat(foo_var,n_copies)  result(new_foo)
         !  Copy base foo object into new new_foo
         new_foo = foo_var
         !  Loop over new_foo (n_copies - 1) times concatenating new
         !  copies of base foo object each time (first copy made above)
            new_foo = new_foo//foo_var
         end do
      !                          Object Querries                             *
      !  Subroutine:  get_Token                                              *
      !  Purpose: Querries a foo object for its lexical token.               *
      !  Arguments:  current_Token  -  Current token to be returned          *
      !               foo_var       -  Foo object which is to be querried    *
      !  References:                                                         *
      subroutine get_Token(current_Token,foo_var)
         type(foo), intent(in)  ::foo_var
         character(len=len(foo_var)), intent(inout) :: current_Token
         !  Loop over elements of token and assemble the output character
         !  string
         current_Token(1:len(foo_var)) = foo_var%token(1)
         do kount = 2,foo_var%size
            current_Token(1:len(foo_var)) = trim(current_Token)// &
         end do
      end subroutine get_Token
      !  Function:  get_Size                                                 *
      !  Purpose: Querries a foo object for the size of its token.           *
      !  Arguments:     foo_var     -  foo object which is to be querried    *
      !  Returns:     token_Size    -  Size of current token                 *
      !  References:                                                         *
      pure function get_Size(foo_var)  result(token_Size)
         integer(kind=I_LO) :: token_Size
         !  Extract token size
         token_Size = foo_var%size
      end function get_Size
      !  I actually have this in another module that uses foo, but it doesn't
      !  matter, it chokes here
      subroutine testFoo(pass_Flag)
         logical, intent(out) :: pass_Flag
         character(len=2) :: test_String
         type(foo) :: test_Foo, foo_Foo
         test_String = '12'
         test_Foo = test_String
         !  Toggle call to foo_repeat/repeat
         foo_Foo = repeat(test_Foo,2)
         !foo_Foo = foo_repeat(test_Foo,2)
         pass_Flag = len(foo_Foo) == 2
         return
      end subroutine testFoo
end module foo_Mod
[/cpp]
Rich
Ok, thanks. I'll investigate.
Andrew_Smith
Valued Contributor I
Is this V11 of the compiler? I have an open support issue with overiden intrinsics not being overriden. I created a simple test case but it worked correctly. My real code overides all the maths functions for a new data type. It compiles and runs in V10.1 but in V11 it complains the data types are wrong while attempting to use the base intrinsic functions. I must create a cut down example that still fails so that I can submit it to support.
Andy
ender01
Andy
Yes, this is V11, I downloaded it this past Friday. You're describing exactly what I'm seeing though it appears to work some times (overloads of len, lle, llt, lge, lgt, and == worked fine, it seems to be just repeat here)
ender01
Duh!! Wouldn't be so bad but I just got done reworking fruit (for unit testing) to address that exact issue. Thanks Steve, you rule!
Cheers,
Rich
