29652 Discussions
GetOpenFileName gives error in virtual memory
Nata_pri
Dear Colleagues! Please help me overcome the problem. As soon as I turn to the GetOpenFileName program, an error "forrtl: severe (41): usufficiant virtual memory" immediately occurs when opening the test file "test.dat". does not work on all versions of compilers (11,18,19). I would be grateful for your help!
program fileopenroot
use nozspe
call initarrs
end
subroutine fileopen(file_spec,ilen)
use comdlg32
use user32
implicit none
character(512) :: file_spec
integer ilen
type(T_OPENFILENAME) ofn
integer*4 NFOBR,status
integer*4 in1
character(*),parameter :: filter_spec = &
  "Text Files"C//"*.dat"C// &
  "Fortran Files"C//"*.dat;"C
character*512   OIFIL
ofn%lStructSize = SIZEOF(ofn)
ofn%hwndOwner = GetForegroundWindow()
ofn%hInstance = NULL  ! For Win32 applications, you
                      ! can set this to the appropriate
                      ! hInstance
ofn%lpstrFilter = loc(filter_spec)
ofn%lpstrCustomFilter = NULL
ofn%nMaxCustFilter = 0
ofn%nFilterIndex = 1 ! Specifies initial filter value
ofn%lpstrFile = loc(file_spec)
ofn%nMaxFile = sizeof(file_spec)
ofn%nMaxFileTitle = 0
ofn%lpstrInitialDir = NULL  ! Use Windows default directory
ofn%lpstrTitle = loc(""C)
ofn%Flags = OFN_PATHMUSTEXIST
ofn%lpstrDefExt = loc("txt"C)
ofn%lpfnHook = NULL
ofn%lpTemplateName = NULL
status = GetOpenFileName(ofn)
if (status .eq. 0) then
  type *,'No file name specified'
else
  ilen = INDEX(file_spec,CHAR(0))
  type *,'Filespec is ',file_spec(1:ilen-1)
  if (IAND(ofn%flags,OFN_READONLY) /= 0) &
    type *,'Readonly was requested'
  end if
  NFOBR=58
         OIFIL="d:/test.dat"C
        in1=108000000
        OPEN(NFOBR,FILE=trim(OIFIL),STATUS='unknown',ACCESS='DIRECT',RECL=in1,FORM='UNFORMATTED',SHARED)
        WRITE(NFOBR,REC=1) IN1
        CLOSE(NFOBR)
        READ(NFOBR,REC=1) IN1
        CLOSE(NFOBR)
return
end
          subroutine InitArrs
           use nozspe
           character*512 :: file_spec = ""C
           integer*4 ilen
           allocate (ASHM(Ndim1D),ASHN(Ndim1D),SHM(Ndim1D),SHN(Ndim1D),AASHM(Ndim1D+1),AASHN(Ndim1D+1))
           allocate (D(ndimB),P(ndimB),T(ndimB),E(ndimB),WM(ndimB),WN(ndimB),TMPARR((ndimB+Ndim1D)*2),TMPARR2((ndimB+Ndim1D)*2))
           allocate (DFUEL(ndimB))
           allocate (EP1(ndimB))
           allocate (ASHL(Ndim1D),VLine(Ndim1D*20),DENS(ndimB))
           allocate (ninfpl(ndimB),ninf(ndimB))
           allocate (NWaveV(Ndim1D),ovol(ndimB),OWaveV(Ndim1D))
           call fileopen(file_spec,ilen)
           return
          end
      module nozspe
      IMPLICIT REAL*8 (A-H,P-Z), LOGICAL*1 (O)
      INTEGER,parameter :: ndim=3000,LdimB=3000,ndimB=10000000
      INTEGER,parameter :: Ndim1D=10001
	  real(8), allocatable, dimension(:):: ASHM,ASHN,SHM,SHN,AASHM,AASHN,D
      real(8), allocatable, dimension(:):: P,T,E,WM,WN,TMPARR
      real(8), allocatable, dimension(:):: DFUEL,TMPARR2,EP1,ASHL
      real(8), allocatable, dimension(:):: VLine,DENS
      integer, allocatable, dimension(:):: NWaveV,ninfpl,ninf
      logical(1), allocatable, dimension(:):: ovol,OWaveV
      end module nozspe
Steve_Lionel
I think that for your particular system, that 400KB allocation is right on the edge of what your system can handle, and calling GetOpenFileName caused Windows to allocate some more, pushing you over the edge. On my PC, it made no difference - it failed either way.
Do you really need a RECL that long? What exactly are you trying to do here?  I agree that Xeffort is not yet 64-bit ready (and may never be.)
Steve_Lionel
Nata_pri
Arrays for visualizing the results of numerical simulations, each 10 million cells (3D modelling). With direct access for fast reading.
Steve_Lionel
I might suggest instead a memory-mapped file. A bit more work on your part, but very efficient. https://docs.microsoft.com/en-us/windows/win32/memory/memory-management-functions#file-mapping-functions
GVautier
New Contributor III
There is no miracle, if you want speed, you need memory.
So if you cannot upgrade to X64 environment, you will probably not be able to got enough memory to reach your goal in term of speed unless you adapt your algorithm to the memory shortage.
Nata_pri
P.S. The error occur at the first operator
