Getting Started???
Andreas_S_1
When I start a new project I cannot select the "Intel Visual Fortran". Hence I cannot build Fortran code. I installed the Visual Fortran Composer XE with the "w_fcompxe_2013.1.119.exe" file. What did I do wrong?
Andreas
mecej4
Did you have a functioning Visual Studio before you installed Intel Fortran? If so, which version, and did you select the option to integrate Intel Fortran into Visual Studio when you were installing Fortran?
