29648 Discussions
Getting error #6410: This name has not been declared as an array or a function. [SIZE]
LFL1
Using the attached code (summary_deallocate_struct.f90), I'm getting the following error when compiling:
$ ifort -c -module ifort  -Iifort summary_deallocate_struct.f90 -o summary_deallocate_struct_ifort.o
summary_deallocate_struct.f90(455): error #6410: This name has not been declared as an array or a function. [SIZE]
do i = 1,size(struct_in2%divertor_plate)
summary_deallocate_struct.f90(463): error #6410: This name has not been declared as an array or a function. [SIZE]
do i = 1,size(struct_in2%divertor_target)
If I remove the following functions from the interface (and also the implementations at the end of the file)  'ids_deallocate_struct':
module procedure ids_deallocate_struct_summary_rmp
module procedure ids_deallocate_struct_summary_runaway115
module procedure ids_deallocate_struct_summary_sol
module procedure ids_deallocate_struct_summary_wall
module procedure ids_deallocate_struct_summary_limiter
It compiles fine when removing these functions.
So, what's going on here? Why am I getting an error on the use of the 'size' intrinseque function?
Why the issue is fixed if I remove the routines indicated above? Could it be that the issue is related to the length of the source file (summary_deallocate_struct.f90) ?
I'm using the following ifort compiler:
$ ifort --version
ifort (IFORT) 19.1.3.304 20200925
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
Thanks a lot for your help.
jimdempseyatthecove
Not seeing the contents of your modules, my guess is one of your modules has a scalar variable named "size".
To correct for this, add ", only: WhatIsNeededHere, OtherItemsHere, ..." to the appropriate use YourModuleHere.
IOW omit the scalar "size"
Jim Dempsey
jimdempseyatthecove
Jim Dempsey
LFL1
I could find indeed a field named 'size' in some source files from the 'ids_schema' module. I could not test for some reason, however I'm already convinced it was the issue.
Thanks a lot!
FortranFan
@LFL1
You may know the solutions provided by the Fortran standard which may help you also INCLUDE:
  1. rename of a module entity in a USE scope e.g. "use ids_schemas, xx=> size" where `xx` is some local entity per the programmer of that scope, say ids_schemas_size.  Meaning the `ONLY` keyword is not necessary unless that is of interest.
  2. apply the `INTRINSIC` attribute in the scope where there can be a name collision
Here is a silly example:
module ids_schemas
   integer :: size = 100
   integer :: foo = 42
end module
   use ids_schemas, ids_schemas_size => size !<-- note the renaming
   type :: t
      integer :: n(2)
   end type
   call sub()
   print *, "main: size = ", ids_schemas_size, "; expected is 100"
   print *, "main: foo = ", foo, "; expected is 42"
   call sub()
contains
   subroutine sub()
      type(t) :: x
      integer :: i
      intrinsic :: size  !<-- note the intrinsic attribute
      do i = 1, size(x%n)
         x%n(i) = i
      end do
      print *, "in sub: x%n = ", x%n
   end subroutine
end
C:\temp>ifort /free /standard-semantics p.f
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.10.0 Build 20230609_000000
Copyright (C) 1985-2023 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.36.32537.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:p.exe
-subsystem:console
p.obj
C:\temp>p.exe
 in sub: x%n =  1 2
 main: size =  100 ; expected is 100
 main: foo =  42 ; expected is 42
 in sub: x%n =  1 2
LFL1
Hello @FortranFan
These are quite convenient solutions indeed. I'm ready to use the first one. However, I will have a look on the 'intrinsic' attribute.
Thanks a lot!
