29386 Discussions
Getting error for library not found: ld: library not found for -lSystem
ManishM
I'm trying to compile a fortran code but it's throwing an error for library not found for -lSystem. I have installed the basic and hpc kit on my Mac Big Sur. Couldn't locate this library in the oneapi package. It is trying to find the said library in the directory:
-I/opt/intel/oneapi/compiler/latest/mac/compiler/include
Any help would be appreciated
mecej4
See if this solves the problem.
mecej4
ManishM
Yeah, it solved the issue. I didn't know the library path is changed to default path rather than in oneapi
volkerblum
I had the same problem upon a fresh install of Big Sur 11.4 and Intel Fortran classic 2021.3
The solution referenced above does solve the issue here as well. However, it's not an entirely obvious step. Is this something that could be checked during installation?
Anyway, I am grateful that the issue was documented here.
