29640 Discussions
Getting error when invoking dummy function when it returns an array
Behrooz_F_
I am trying to invoke an external function through a dummy function name. The error is:
Error    1     error #6634: The shape matching rules of actual arguments and dummy arguments have been violated.
the code is:
Module DummyFG
contains
    function DF(DummyF, x,n)
      implicit none
      integer :: n
      real(kind=8) ,intent(in):: x(n)
      real(kind=8) :: DF
      real (kind=8) :: DummyF
      DF = DummyF(x,n)
    end function DF
    function DG(DummyG, x, n)
      implicit none
      integer :: n
      real(kind=8) , intent(in):: x(n)
      real(kind=8) :: dG(n)
      real (kind=8), external :: DummyG
      dg= DummyG(x,n)
    end function DG
end Module DummyFG
   function f(x,n)  !result(f1)
        implicit none
        real(kind=8) :: f
        real(kind=8) ,intent(in) :: x(n)
        integer :: n
        f=(1.0-x(1))**2+100.0*((x(2)-x(1)**2))**2;
    end function f
   function G(x,n)  result(g1)
        implicit none
        integer :: n
        real(kind=8) :: g1(n)
        g1(1)=-2.0*(1.0-x(1))-400.0*x(1)*(x(2)-x(1)**2)
        g1(2)= 200.0*(x(2)-x(1)**2)
    end function g
The driver routine is:
 program Test
    implicit none
    ! Variables
    integer, parameter :: n=2
   real(kind=8) :: x(n)=(/2.0,1.0/)
   call check(x,n)
   contains
   subroutine check(x,n)
   use dummyfg
   implicit none
    interface
    function f(x,n)
        implicit none
        integer :: n
        real(kind=8) :: f
        real(kind=8) ,intent(in) :: x(:)
        end function f
     function g(x,n) result(g1)
        implicit none
        integer :: n
     end function g
    end interface
   integer :: n
   real(kind=8) :: x(n),fc, gc(size(x))
   fc=df(f,x,n)
   gc=dg(g,x,n)
   end subroutine check
    end program Test
Any help is appreciated very much!!!
mecej4
The interface that you provided in Subroutine Check contains an inconsistent declaration, "real(kind=8) ,intent(in) :: x(:)" -- inconsistent because in the code for f(x,n) you have "real(kind=8) ,intent(in) :: x(n)". Similarly, the declaration "real (kind=8), external :: DummyG " in the code for function DG is incorrect. The actual argument for DummyG is a function that returns not a single real(kind=8), but an array of that type. Therefore, an explicit interface for DummyG is needed and you have not provided one.
Consider declaring CONTAINed functions in modules and USE those modules, in order to avoid the risk of providing multiple and inconsistent interfaces. Better yet, when you write subprograms that take one or more procedure arguments, provide abstract interfaces to those  procedures in a module, USE that module to make the interfaces available, and declare the dummy procedure arguments using something along the lines of "procedure(dgproc) :: DummyG".
I have attached a modified version of your code with just enough fixed that it works correctly. However, it is better to change the design along the lines that I stated above.
Behrooz_F_
mecej4,
Thanks for your quick and insightful response. I appreciate it very much!
