Getting error while using random_seed()
Ramesh
I am doing the migration of one of my codes from AIX to Linux. In my program I am calling random_seed() function. It was compiled correclty using xlf but getting syntax error with ifort.The following is the piece of code.
call random_seed(generator=2)
call random_seed(put=iseed1(1:ksize))
Error: This is not a valid keyword.   [GENERATOR]
Please help me how to replace this routine.
Ramesh Naidu
mecej4
If GENERATOR is a keyword that works with IBM Fortran on AIX, it is a vendor extension. The Fortran standard specifies
13.7.136 RANDOM SEED ([SIZE, PUT, GET])
Unless you can find a description of the algorithm used by IBM for the selection GENERATOR=2, you will have to accept the standard RNG provided by the Intel compiler, to do which you should just remove the first of your two CALL statements.
