Go to location
burgnies
I've just installed Intel fortran, and i have a troubleshooting :
I can't go to the location of thelineerror in source code when i double-click in the error message in the output window. I try also with "go to location", but with no more success. Line is well shown in bracket in the error message.
Somebody have an idea of the problem ?
That's one I have not seen before. Normally one just single clicks on the error message. Can you try this with a new project with a simple source that has an error and see if the problem is still there?
burgnies
I don't no exactlythe reason, but i had to install Intel fortran two times beforeit work correctly. May be a "competition" with the old Compaq version in PC that i killed.
So, now it's OK. Thank's a lot for your attention.
