Graphics in Intel Fortran Compiler
gamma-jm
How can I easy graphics and windows under Intel Fortran Compiler for Windows?
Where can I find the documentation from the commands (for example: line, circle..)?
Dishaw__Jim
Is your goal to produce plots of data (e.g. XY chart) or do you need to access to the graphics (e.g. rendering).
For plotting data I use PLplot. I find it easier than the new, but no longer supported, Array Visualizer.
gamma-jm
I want to produce a Window for Data entering and draw easy drawings like circles.
Read about QuickWin in the compiler's documentation under Building Applications.
gamma-jm
Thanks for the Information and I read too abaout Array Visualizer, but I couldn't do a example.
Do you have easy examples for both: QuickWin and Array Visualizer in order to compile from Console (DOS-Windows)
Thank you
Version 10 of the compiler comes with three QuickWin samples: Calendar, QWPaint and SciGraph. These should give you a feel for what is possible. Each one has a build.bat script which builds the application.
