Hello! ...
Santosh_R_
Hello!
I am trying to run the following program but I am ending up with an error.
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
a.out              0000000000402BFA  Unknown               Unknown  Unknown
a.out              0000000000402AAC  Unknown               Unknown  Unknown
libc.so.6          000000341AC1ED1D  Unknown               Unknown  Unknown
a.out              00000000004029A9  Unknown               Unknown  Unknown
Please help me
program roots
      implicit none
      real :: p,q,r, x_r1,x_r2,x_im1,x_im2
      write(*,*)"please enter the values of the follwing variables"
      write(*,*)"a,b,c"
      read(*,*) p,q,r
      call rootsfind
      write(*,*) "x_real1=",x_r1,"x_real2=", x_r2
      write(*,*) "x_imag1=",x_im1,"x_imag2=", x_im2
      stop
      end program roots
     ! started writing the subroutine
      subroutine rootsfind(a,b,c,x_real1,x_real2,x_imag1,x_imag2,i)
      implicit none
      real::discr,d
      real,intent(in)::a,b,c
      real,intent(out)::x_real1,x_real2,x_imag1,x_imag2
      integer,intent(out)::i
      real,parameter::epsilon=1e-05
      if (abs(a)<=epsilon) then
      x_real1=-b/2*a;x_real2=0
      x_imag1=0;x_imag2=0
      i=1
      return
      end if
      discr=b*b-4*a*c
      d=sqrt(discr)
      if (discr>=0)then
        i=2
        x_real1=(-b+d)/2*a
        x_real2=(-b-d)/2*a
        x_imag1=0;x_imag2=0
       else
        i=3
        x_real1=-0.5*b/a; x_real2=x_real1
        x_imag1=0.5*d/a;x_imag2=-x_imag1
      end if
      end subroutine rootsfind
jimdempseyatthecove
Your
call rootsfind
is not supplying the arguments to
Jim Dempsey
Santosh_R_
Dear Jim Dempsey,
I am new to Fortran programming Please elaborate it a bit
Thank you
Santosh R
Santosh_R_
Dear Jim Dempsey,
Thank you so much I could rectify this error now.
Santosh R
jimdempseyatthecove
Additional information you may find of use.
In your original program, you were setting variables in the scope of the PROGRAM ROOTS, then making the call to ROOTSFIND. This is one instance of performing the method in rootsfind. Now then, assume in your PROGRAM ROOTS you want to make the call to ROOTSFIND in multiple places, each call using the same argument lists. Also assume that ROOTSFIND is never to be called from elsewhere from ROOTS. In Fortran there is a means to permit the called subroutine to have access to the namespace of the CALL-er.
**** untested code ***
program roots
       implicit none
       real :: a,b,c, x_real1,x_real2,x_imag1,x_imag2
       integer :: i
       write(*,*)"a,b,c"
       read(*,*) a,b,c
       call rootsfind
       write(*,*)"a,b,c", a,b,c
       write(*,*) "x_real1=",x_real1,"x_real2=", x_real2
       write(*,*) "x_imag1=",x_imag1,"x_imag2=", x_imag2
       write(*,*) "i=",i
       c = 0.0
       call rootsfind
       write(*,*) "i=",i
       b = 0.0
       call rootsfind
       write(*,*) "i=",i
       stop
       contains
         implicit none
         real::discr,d
           x_imag1=0;x_imag2=0
           i=1
           return
         end if
         discr=b*b-4*a*c
         d=sqrt(discr)
         if (discr>=0)then
           i=2
           x_real1=(-b+d)/2*a
           x_real2=(-b-d)/2*a
           x_imag1=0;x_imag2=0
         else
           i=3
         end if
end program roots
Jim Dempsey
Santosh_R_
Dear Jim Dempsey,
Thank you ver much for your kind reply. It is very useful for beginners like me.
I will definitely be in touch with you and need your help
Thank you.
Santosh R
FortranFan
Santosh R. wrote:
.. I am new to Fortran programming ..
@Santosh R.,
You may want to look up these sources if you plan to delve more into Fortran:
