29650 Discussions
Help for Quickwin using Intel Fortran
shenhawju
I have a simple Quickwin Fortran program that can be compiled by CVF 6.6 without any program. However, I always get the error in Intel Fortran 7.0. The major error is
Error FCE37 : Module DFLIB not found
Could anyone give me help. Many thanks.
In Intel Fortran 7.x, you need to replace USE DFLIB with
INCLUDE 'FLIB.FD'
You may find some other changes are needed - Intel Fortran 7.x's QuickWin implementation is somewhat different from CVF's. This will all be reconciled in the future Intel Visual Fortran.
Steve
Jugoslav_Dujic
Valued Contributor II
...or, nicer, do it yourself:
MODULE DFLIB
INCLUDE "FLIB.FD"
END MODULE DFLIB
when/if porting to CVF/IVF, just remove the module above from the project.
Jugoslav
No - this won't work. IF 7.1 will refuse to compile it because it disallows STRUCTURE/RECORD in MODULEs.
Steve
