Help in using help for commands
davidgraham
If I press F1 when the cursor is on some blue text (such as 'case') I get the help on that command.
If I press F1 when the cursor is on some black text (such as 'GetDlgItem') I get 'no results found'.
I must have my Help set up wrong.
It does say filtered by 'Intel'.
This did work in CVF so I must be doing something wrong.
Which update of Intel Fortran do you have? Some people had that problem with earlier updates, but Update 8 fixed it for almost everyone.
davidgraham
Sorry, I can't find where it gives the version number.
The last email I received was in December 2011 and I updated version IVF update 8, but it was now called Intel Visual Fortran Compiler XE Version 12.1 Update 2.
I did update this.
Either one of those version identifications is fine. You can get the version using Help > About and then clicking on Intel Visual Fortran.
Please try again when Update 9 comes out in the next week or two.
