29342 Discussions
Help to catch Arrow key event under Windows 10
cean
New Contributor II
I am using OneAPI Fortran 2023.2.0 to write a Win32 program on Windows 10. Where could I catch the Arrow key event? I can catch normal keys under WM_KEYDOWN. But the code below doesn't work for Virtual Key like the Arrow Keys.
Thanks for help.
Cheers,
Cean
integer function WndProc( hwnd, message, wParam, lParam )
    select case (message)
        case (WM_KEYDOWN)
            wParam = and(wParam, #0000ffff)
	        select case (wParam)
            case (VK_LEFT)
				!// Process the LEFT ARROW key.
				ret = MessageBox (hwnd, "Left arrow is pressed"C, "Hi"C, MB_OK)
				return
			case (VK_RIGHT)
cean
New Contributor II
Thanks. I should not call the TranslateMessage function.
andrew_4619
Do you have any PeekMessage calls within you message processing that are intercepting these keystokes maybe?
Also if the cursor is in certain windows e.g. in a text box the arrowed keys get intercepted by windows for the carot position movement maybe that is a problem.
cean
New Contributor II
