I am using ifort version 15.0.1 to compile and build my code with the open source PETSc and MPI
Compiling has no error msg but during building, I got the errors below, though in the end the build completed with a working a.out. However, I'm still worried there's some underlying problems. What do these errors mean?
ipo: warning #11021: unresolved xcb_connection_has_error
Referenced in /usr/lib64/libX11.so
Here are some more errors such as:
ipo: warning #11021: unresolved __xmlGenericError
Referenced in /app1/centos6.3/Intel/mvapich2-2.1/lib/libmpi.so
However, I can't post them since it says:
Your submission has triggered the spam filter and will not be accepted. If you feel this is in error, please report that you are blocked.
It looks as if you need to add some additional library to the link step. I don't know which library defines those symbols.
ok thanks anyway.
