Help with first-time DLL please
michael_green
I've managed to create my first DLL successfully. It's based on the example in ...DF98/samples/dll/loadexp1.
I notice that when I build the example I get an output telling me "1 file(s) copied" - this is presumably the dll itself being copied to the main program's directory. In my case I have had to make a similar copy manually because I cannot find where in the build setup this automatic copy is specified. Am I correct in my assumption here, and if so please could someone enlighten me as to how it is done?
With many thanks in advance
Mike
sabalan
You can see the path and file name under Project / Sttings... / Link tab / Output file name.
Sabalan.
Lorri_M_Intel
The "copy" is happening as part of the post-build.
To see that, in the LoadEXP1 sample, go to Project-Settings, then to the rightmost tab, called "Post Build". You'll need to use the arrow box beside the tabs in order to get over there.
Does that help?
- Lorri
