Help with openMP implementation of Fortran Code
Seitz__Sebastian
Einsteiger
2.752Aufrufe
Dear all,
I am new to programming with Fortran's openMP application (using Intel Compiler version 18). I recently have run into a problem to which I could not find an answer (after 1 month of digging around). The issue is (see below for the code) that I would like to solve a function where I assign some limiting conditions in the main body of the code, which also should be used in the function. For example, I specify that my function should allow for a current value A_cur=a0(i,j) where i and j are my do-loop running variables.
The issue is that in my main body of code, this assignment works fine. But as soon as I "call" my function f(x) where x not equal A_cur (but A_cur is a constant used in the function), my code reads A_cur=0 instead of A_cur=a0(i,j).
Hence, my question is how to solve this issue without defining the function f(x,a_in) where I set, a_in=A_cur? I would be really grateful for some insights on this issue as well as some recommendations.
This code is supposed to illustrate my issue with a very simple assignment (which however captures the issue). In this code, I specify that a_com=i, whereby i is the running variable in my OMP loop. In the main code it correctly takes the assigned value but it does not do so in the function utility. (Note that this is a simplified version of the assignment problem I mention above where the assignment issue between main body of the code and the function does not affect the outcome, while in my example above it would).
module constants
integer, parameter:: i4b=selected_int_kind(15)
integer, parameter:: ndp=selected_real_kind(15)
real(ndp), parameter:: zero=0.0d0
real(ndp), parameter:: one=1.0d0
real(ndp), parameter:: two=2.0d0
integer(i4b):: t_in, a_com
real(ndp):: y_cur,a_cur
    contains
    double precision function utility(in)
        real(ndp),intent(in):: in
        real(ndp):: v1, cons
        if((t_in)<two)then
            cons=1+in
            write(*,*) 't_in<2'
        else
            cons=2+in
            write(*,*) 't_in>2'
        endif
        write(*,*) 'a_com', a_com
        v1=sqrt(cons)
        utility=v1
    end function utility
end module constants
program test_openMP
    use constants
    !# Define some variables
    integer(i4b):: i,t,j
    integer(i4b), parameter:: i_max=10, t_max=3, j_max=3
    real(ndp):: result(0:i_max,0:t_max,0:j_max), a_pr(0:i_max,0:t_max), &
                income(0:j_max)
    real(ndp):: a_in,a_max
    a_max=100
    do i=0,i_max
        do t=0,t_max
            a_pr(i,t)=(a_max)/((1+0.05*t)**i)
        enddo
    enddo
    do j=0,j_max
        income(j)=(1.07)**(1+j)
    enddo
    do t=0,t_max
        t_in=t
        write(*,*)'Run for t', t, 'of', t_max
    !$OMP PARALLEL DO PRIVATE (a_in,y_cur,a_cur,a_com)
    do i=0,i_max
    write(*,*)'Run for i', i, 'of', i_max
        a_in=a_pr(i,t)
        a_com=i
            do j=0,j_max
                y_cur=income(j)
                a_cur=a_in+y_cur
                result(i,t,j)=utility(a_cur)
            enddo
        enddo
    !$OMP END PARALLEL DO
    !a_com=o
    enddo
    do i=0,i_max
        t=2
        j=1
            write(*,*) 'i', '|', 'a_pr','|', 'Result','|', 'Utility'
            write(*,*)'###############################################'
            write(*,*)  i,'|', a_pr(i,t),'|', result(i,t,j),'|', utility(a_pr(i,t)+income(j))
    enddo
end program test_openMP
Best,
Sebastian
6 Antworten
John_Campbell
Neuer Beitragender II
2.752Aufrufe
private variable a_com is different to the module variable a_com in utility, although it is not used. I would also recommend that array result is shared.
I changed your test example by : removing writes in Utility, declaring shared variables and including a record of thread in use.
The changed example produces similar results for both single thread and multi-thread, although I am not sure if it addresses your problem. It may give you some ideas ?
module constants
 integer, parameter:: i4b=selected_int_kind(8)
    contains
         if((t_in)<two)then
             cons=1+in
!             write(*,*) 't_in<2'
         else
             cons=2+in
!             write(*,*) 't_in>2'
         endif
!         write(*,*) 'a_com', a_com
         v1=sqrt(cons)
         utility=v1
program test_openMP
    use constants
    USE omp_lib
     integer(i4b):: i,t,j, id
                 income(0:j_max)
     integer(i4b):: last_thread_used(0:i_max)
     a_max=100
     do i=0,i_max
         do t=0,t_max
         enddo
     enddo
     do j=0,j_max
     enddo
     do t=0,t_max
         t_in=t
      !$OMP PARALLEL DO PRIVATE (a_in,y_cur,a_cur,a_com, id)   &
      !$OMP             SHARED  (a_pr, income, result, last_thread_used)
         do i=0,i_max
             id = -1
      !$     id = omp_get_thread_num()
             last_thread_used(i) = id
             write(*,*)'Run for i', i, 'of', i_max, id
             a_in=a_pr(i,t)
             a_com=i
             do j=0,j_max
                 y_cur=income(j)
                 a_cur=a_in+y_cur
             enddo
         enddo
      !a_com=o
     enddo
     do i=0,i_max
       t=2
       j=1
       write(*,*)  i,'|', a_pr(i,t),'|', result(i,t,j),'|', utility(a_pr(i,t)+income(j)),last_thread_used(i)
     enddo
Greg_T_
Geschätzter Beitragender I
2.752Aufrufe
If additional information about OpenMP would be helpful in getting started, there is a very good set of notes and examples available at LLNL:
https://computing.llnl.gov/tutorials/openMP/
And the "Introduction to OpenMP" videos by Tim Mattson from Intel available on YouTube is excellent.  This should be the URL to that collection of videos:
https://www.youtube.com/playlist?list=PLLX-Q6B8xqZ8n8bwjGdzBJ25X2utwnoEG
Regards, Greg
Seitz__Sebastian
Einsteiger
2.752Aufrufe
Dear Greg, dear John,
thank you for your helpful comments. Unfortunately, my program is still not running. The above example now does, but the actual code is a little bit more complex than the easy case above. In general, it helped me to know that the variables within the module are regarded as different variables when using openMP as the issue seems to be be partially alleviated if I write the (private) variables as inputs into my subroutine.
That being said, even if this subroutine contains a function then, the program does not seem to write correctly into this function. As annoying as this is at the moment, I have decided to move on (I need to work on the open MPI implementation as well). Do there exist similar great sources as the ones you have mentioned, Greg?
Best,
Sebastian
jimdempseyatthecove
Geehrter Beitragender III
2.752Aufrufe
module variables are SHARED unless stated differently (OpenMP clause or threadprivate)
Inside the function utility (in post #2), t_in and a_com are the module (shared) copy (also the main thread's values).
However, in the !$omp loop,   t_in and a_com are the private copies, with exception that for the main thread they are the same as the module variables.
Jim Dempsey
Seitz__Sebastian
Einsteiger
2.752Aufrufe
Dear Jim,
in my main code I actually used to define them as:
integer(i4b), private:: t_in, a_com
I thought this would then make this variable threadprivate in my module. Am I mistaken about that?
If there is another way of making them threadprivate (within the module where I define my function), I would be very grateful to know this way. The only other way I have found is to explicitly write these variables into my subroutine/ function and declare them as private in my !$OMP statement/call.
Best,
Sebastian
jimdempseyatthecove
2.752Aufrufe
This does not make the variable threadprivate. What it does is makes the variable hidden from view outside the scope of the module.
OpenMP has compiler directives that need not be associated with a parallel region.
module
!$omp threadprivate(t_in, a_com)
contains
! code follows
Jim Dempsey
Antworten
