29616 Discussions
Help with trimming character variable
remkoduursma
Sorry for the noob question - but I have trouble using TRIM on a character string to get rid of trailing blanks.
PTITLES is an array, defined as
CHARACTER PTITLES(10)*(*)
I read it from a file like this, in a loop:
READ (UPHY, *) PTITLES(I)
There are plenty of trailing spaces,
so I do:
PTITLES(I) = TRIM(PTITLES(I))
The result is not modified at all from the original...
any help?
thanks,
Remko
bmchenry
New Contributor II
If output format/spacing is all you are worried about, then a way to handle trailing spaces is to use the LEN_TRIM function:
namelength(i) = Len_Trim(filename(i))
Then to write simply use:
write(*,*) Filename(i)(:namelength(i))
clips the spaces on output
When you assign the trimmed value to PITTLES(I), it gets blank padded again to its origibal length. Typically you do the TRIM at the point where you are going to display or use the value, for example:
WRITE (*,*) "xxx" // TRIM(PITTLES(I)) // "yyy"
Version 11.1 supports the Fortran 2003 feature of assumed-length allocatable character variables so you could have something like this:
CHARACTER(:), ALLOCATABLE :: VARYING_STRING
VARYING_STRING = 'ABCD' ! Length 4
VARYING_STRING = '12345' ! Length 5
In the current update, you need to compile with /assume:realloc_lhs to get this to work, but that requirement will disappear in the next (I think) update.
Note that you can't just slap this in to your existing code as if you're passing these as arguments then explicit interfaces are required.
bmchenry
New Contributor II
