Hiding Console Window
dannycat
I have a procedure within a FORTRAN Windows application that has the potential to loop several hundred times and during each loop I use the SYSTEM('Batchfile.bat') function to run an external executable program. Currently when the program runs a console window is displayed every time this function is called and this can be a bit annoying for the user. Does anyone know of analternative way to execute a program from within a FORTRAN (Windows) application where you can prevent the window being displayed. I looked into CreateProcess API function but the documentation is a bit confusing so I'm not sure if this is the way forward.
Any help on this will be much appreciated.
Arjen_Markus
Have you tried with:
call system( "start /b mybatch" )
(help start will inform you about the other options the command has) Not sure it does work, but it seems a likely possibility.
Arjen
ShellExecute is easy to use. Do you need to wait for the program to complete? If so, then CreateProcess will be needed.
dannycat
Steve,
As I need it to wait for process to finish Idecided to use CreateProcess. I've managed to get it to work apart from waiting. See the code below:
logical function w32_CreateProcess(exefile, infile)
! Use Crate Process API to execute external program
use dfwin
! Arguments
character*(*),intent(in) :: exefile
character*(*),intent(in) :: infile
! Local variables
character*255 :: cmd_line
Type(T_Process_Information) :: pi
type(T_StartupInfo) :: si
type(T_SECURITY_ATTRIBUTES) :: sao,sap,sat
integer(DWORD) :: iret
integer(HANDLE) :: hfile,err
! Initialise
w32_CreateProcess = .false.
! Set up command line
cmd_line = trim(exefile)
! proc sec attributes
sap%nLength = sizeof(sap)
sap%lpSecurityDescriptor = NULL
sap%bInheritHandle = 1
! thread sec attributes
sat%nLength = sizeof(sat)
sat%lpSecurityDescriptor = NULL
sat%bInheritHandle = 1
! set attributes for the error file
sao%nLength = sizeof(sao)
sao%lpSecurityDescriptor = NULL
sao%bInheritHandle = 1
! Open File for reading
hFile = CreateFile (trim(infile)//char(0), GENERIC_READ, &
FILE_SHARE_READ, sao,OPEN_EXISTING, &
FILE_FLAG_SEQUENTIAL_SCAN, NULL)
if (hFile.eq.INVALID_HANDLE_VALUE) then
call grp_message("ERROR: Creating File err.log")
return
end if
err = CreateFile('err.log'C, &
ior(GENERIC_WRITE,GENERIC_READ), &
ior(FILE_SHARE_READ,FILE_SHARE_WRITE), &
sao, &
CREATE_ALWAYS, &
FILE_ATTRIBUTE_NORMAL,NULL)
if(err.eq.INVALID_HANDLE_VALUE) then
return
endif
! Set up Startup Data structure
si%cb = sizeof(si)
si%lpReserved = NULL
si%lpDesktop = NULL
si%lpTitle = NULL
si%dwX = NULL
si%dwY = NULL
si%dwXSize = NULL
si%dwYSize = NULL
si%dwXCountChars = NULL
si%dwYCountChars = NULL
si%dwFillAttribute = NULL
si%dwFlags = ior(STARTF_USESHOWWINDOW,STARTF_USESTDHANDLES)
si%wShowWindow = SW_HIDE
si%cbReserved2 = 0
si%lpReserved2 = NULL
si%hStdInput = hFile
si%hStdOutput = err
si%hStdError = err
! Create Process
iret = CreateProcess(NULL, & ! No module name (use command line)
trim(cmd_line)//char(0), & ! Full Command Line
loc(sap), & ! Process handle not inheritable
loc(sat), & ! Thread handle not inheritable
TRUE, & ! Set handle inheritance to FALSE
ior(NORMAL_PRIORITY_CLASS,CREATE_NO_WINDOW), & ! No creation flags
NULL, & ! Use parent's environment block
NULL, & ! Use parent's starting directory
loc(si), & ! Pointer to STARTUPINFO structure
loc(pi)) ! Pointer to PROCESS_INFORMATION structure
if(iret.ne.0) then
! wait until the process is done
iret = WaitForInputIdle(pi%hProcess,INFINITE) ! time-out interval in milliseconds
iret = CloseHandle(pi%hProcess)
iret = CloseHandle(pi%hThread)
iret = CloseHandle(err)
iret = CloseHandle(hfile)
w32_CreateProcess = .true.
endif
return
end function
This function assigns the input ($CONIN)and output ($CONOUT) using CreateFile
I don't want to put sleepQQ(time) is the code as this is messy and will slow down the process too much if a time high enough to cover fluctuations in server responses etc is used.
The WaitForInputIdle seems to be ignored which the documentation says is the case when running as a GUI process though it does explain what these are. (None consule perhaps).
What do I need to do to resolve this?
WaitForSingleObject can be used to wait for process completion. See here.
dannycat
Ah yes, thats done the trick! I've replaced WaitForInputIdle with WaitForSingleObject (and moved the CloseHandle functions outside the if(CreateProcess... block as they need to be called even when CreateProcess fails.
Thanks Steve
Geoff_Hall
Hey thanks for your post dannycat. Your code helped by to solve a different, but related, problem I was having with reassigning std handles in CreateProcess :)
Cheers, Geoff
