Higher Resolution then SleepQQ
onkelhotte
New Contributor II
Hi there,
I want to "slow down" my calculations, so the user can see the results better.
For that I measure the elapsed time and call the sleepqq function for the remaining time [sleepqq(dt-elapsedt ime)] in ms of course.
But now I want to speed it up, something like 2x, 5x, 10x and maximum Intel CPU Power. When using 5x speed, the program should suspend for 10ms, for 10x its 5ms. But sleepqqs resolution is not high enough, so there is no difference between sleepqq(10) and sleepqq(5) or (of course not) for sleepqq(1).
Is there any way to be more precise? I switched to the SleepEx function, there the situation is a little bit better, but not perfect.
In an older question Steve recommend the "Multimedia Timers", but I dont understand how to use them for this purpose.
Im using IVF 11.0.
Thanks in advance,
Markus
jimdempseyatthecove
Under Windows look at
QueryPerformanceCounter and QueryPerformanceCounterFrequency.
With these you can get the current CPU "tick" and the tick rate. The tick rate is your CPU clock rate (or FSB clock rate).
Using the Frequency (ticks per second) produce a delta == to the number of ticks to stall. 1us would be the tick rate / 1000000;
The structure of the performance counter contains a union with a quad part. This is usable as-is as an __int64 type variable.
LARGE_INTEGER now, whenok, freq, deltaTicks;
QueryPerformanceFrequency(&freq); // need only be done once
// freq.QuadPart contains ticks per second
// compute desired delta
// 100us =
deltaTicks.QuadPart = (freq.QuadPart / (__int64)1000000) * 100;
QueryPerformanceCounter(&now);
whenok.QuadPart = now.QuadPart + deltaTicks;
while(now.QuadPart < whenok.QuadPart)
Sleep(0); // or_mm_pause()
Jim Dempsey
jimdempseyatthecove
// 100us =
Jim Dempsey
onkelhotte
New Contributor II
Thanks Jim for the answer.
This is the Fortran code:
[bash]use ifwin
real(kind=4) fSleepTime
integer(kind=8) freq, now, whenok, deltaTicks
logical l
!Just call once in your code
l = QueryPerformanceFrequency(loc(freq))
!Use this in your waiting routine
fSleepTime = 0.2 !Time in seconds
deltaTicks = freq * fSleepTime
l = QueryPerformanceCounter(loc(now))
whenOk = now + deltaTicks
do while(now .lt. whenok)
    l = sleepEx(0, .false.)
end do [/bash]
Markus
