How To Install GDB-IA Only.
James_C_6
Our application is a fortran based application. The standard GDB that comes with Linux is not sufficient in debugging issues on production systems. We would like to install GDB-IA on those servers. Can I just install GDB-IA without instlling the entire package? If so, how please respond with the syntax? Is the version of GDB-IA that comes with compoer2015 backwards to prior versions?
