29359 Discussions
How can I get an older HPC toolkit (2024.2.1)?
spainchaud
I have a Fortran modeling library that started giving NaNs where it was previously giving reasonable numbers. The only change was going from the IFORT compiler to IFX. I need to test with the older compiler. Since my computer is only about 1 month old, I only have 2025.2.1 installed. I have been able to download the base toolkit 2024.2.1, but I have not found a link to the corresponding HPC toolkit.
I usually only have one Fortran install on my computer. Is there any issues with having multiple versions installed?
Mark_Lewy
Valued Contributor I
IFX 2025.3 produces the same results as IFORT
C:\Users\lewym\source\sandbox\DivisionTest>ifx DivisionTest.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2025.3.0 Build 20251010
Copyright (C) 1985-2025 Intel Corporation. All rights reserved.
Microsoft (R) Incremental Linker Version 14.44.35211.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:DivisionTest.exe
-subsystem:console
DivisionTest.obj
C:\Users\lewym\source\sandbox\DivisionTest>.\DivisionTest.exe
 (-5.041342791822924E-004,-1.401566961551337E-002)
Using a VS 2022 solution with the default options, both debug and release configurations produce the same result.
andrew_4619
IFORT is no longer supplied by Intel. Rather than hunt around for different compilers why mot use the debugger to fins why the nans are made. It could be a non conformance (bug) in your code that just happens to be exposed by a different compiler/options.
spainchaud
Although I have debugged into the Fortran DLL many times in the past, it does not seem to want to work today. I am calling the Fortran from C++ and the C++ from C#. Sometimes the native code debugging just stops working, and it is difficult to figure out why, since I never touch those settings.
If there is non-compliant Fortran code, it has been working for 15+ years.
andrew_4619
"If there is non-compliant Fortran code, it has been working for 15+ years." - probably/possibly but no guarantee! Why not add a few isnan calls at some strategic locations in the Fortran code to at least try to isolate where the first nan appears and then home in on the why....
ISNAN is elemental so you can also apply any(isnan(myarray)).....
spainchaud
I found the version of oneAPI 2024 used on our build server and rolled back. I was able to create test code to verify a bug in the IFX compiler. I took the complex values used from our 16-year-old numerical modeling code.
program DivisionTest
implicit none
COMPLEX*16 A, B, C
A = DCMPLX(-1.811004047684485D-316,7.977508024816439D-317)
B = DCMPLX(-5.220325499023662D-315,-1.310905257053363D-314)
C=A/B
print *, C
end program DivisionTest
With the IFX compiler I get C=(NaN,NaN)
With the IFORT compiler I get C= (-5.041342791822924E-004,-1.401566961551338E-002).
I have no idea how to fix what the IFX compiler is doing. Even if I could fix the problem, there would be thousands of lines to review. Fixing the problem would be a project all by itself.
Mark_Lewy
-subsystem:console
DivisionTest.obj
andrew_4619
I will note also that in recent months some bugs with complex type have been recorded  in IFX. I will also note that some (maybe all) of those are now fixed.
