29375 Discussions
How can I show all the elements of an array when I was debugging?
quyunfeimsu_edu
I'm using Visual Fortran compiler to debug my program, and I need to look at all the element of the array, but it only shows part of elements. Like picture shows above: only shp(1:4,1) were displayed, butthe shp is defined as 4*8 matrix in this subroutine. How can I show all of the elements of shp? anyone can tell me?
Yofee
You're looking at the tooltip, which by necessity is abbreviated. Find your variable in the Locals tab, typically at the bottom-left of the screen.
quyunfeimsu_edu
Thank you very much for replying!
I also look at the locals tab, and it still doesn'tshow me the whole array. I type shp(1,2), one of the element of the array, in quickwatch to see its existence in locally.
How can I see the whole picture of the array?
Thanks again!
Yofee
It looks to me as if it is showing the whole array. How is the array declared?
quyunfeimsu_edu
definition+of+shp.docx
Thanks for Steve's help:
I don't know what's going on for me, the definition of this array, please seethe attached file "definition+of+shp.docx".
Except this, is there any alternative conevient ways to let me display all the elements that I want?
Yofee
Ok, that helps. You declared shp as an assumed-size array with * as the last dimension. The debugger has no idea how big the array is, so it uses 1. As you noted, you can access individual elements. You can also put shp(1:4,1:7) in the watch window.
I'm a bit puzzled why you used * here when the source seems to know exactly the size of the array.
I'd also ask that, in the future, you attach text files or Fortran source files directly rather than Word documents.
