29594 Discussions
How can a parllel Fortran loop (OpenMp) call an external function or subroutine correctly?
vahid_a_
Greetings, community!
The code below calls a simple scalar-valued function from a parallel loop. As can be seen from the test result, the parallel mode result of the function call (array a) is 0. There's something wrong with this! In serial mode, the code works fine.
Could you please suggest a clean/easy workaround for this type of call from a parallel loop? Searching for an answer didn't yield any results...
I would also appreciate if you could point out a good reference book that discusses this type of problems/tutorials.
The code:
module init
	integer, parameter :: nx = 5
	real, dimension(1:nx) :: order_parameter,a,b
	contains
	real function h(phi) !result(h)
        real :: phi
        h = phi**3*(10.0 - 15.0*phi + 6.0*phi**2)
    end function
end module
program main
	use omp_lib
	use init
	implicit none
	integer :: i
	order_parameter = [ 0.0,0.25,0.5,0.75,1.0 ]
	!$OMP PARALLEL default(private) &
	!$OMP shared(a,b)
    !$OMP do
	do i=1,nx
		a(i) = h(order_parameter(i))
		b(i) = 1.0
	end do
    !$OMP end do
    !$OMP end parallel
	write(*,*) order_parameter
	write(*,*) 'a:',a
	write(*,*) 'b:',b
end program main
PARALLEL run output of "ifort -O2 -qopenmp openmp_func_call_test.f90" on Mac OS:
  0.0000000E+00  0.2500000      0.5000000      0.7500000       1.000000
 a: -7.6655056E-26  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00
 b:   1.000000       1.000000       1.000000       1.000000       1.000000
SERIAL run output of "ifort -O2 openmp_func_call_test.f90" on Mac OS:
 a:  0.0000000E+00  0.1035156      0.5000000      0.8964844       1.000000
Arjen_Markus
The problem is that the variable order_parameter has the attribute "private", as that is the default. I realised this when I printed the values inside the do-loop. Add it to the list of shared variables and the program works correctly. (BTW: As i is an iteration variable it is automatically made private and handled correctly)
