29633 Discussions
How do I debug 1 and 2 byte variables?
billsinclaol_com
I am supposed to be able to set a data breakpoint when a particular location has changed.
But there is a problem if the variable is not 4 bytes long. It alwaysthinks I want to
examine 4 bytes anyway.I don't see a way to make that any shorter.
For example:
Interger*1 ix(40)
If I set a data breakpoint for just ix(1) it wants to set breakpoints for 2,3, and 4.
So I get a lot of extra fooling around for locations I don't care about.
Doesn't the debugger know about anything shorter than 4 bytes? You get those
in C++ as well.
WSinc
Never mind -
I figured out how to do this, but I am wondering why the debugger
can't make it automatic, rather than always setting the length to 4 bytes.
Then we won't have to go in and change it.
garyrwaters5428
It would be nice if you documented the solution here so others would not need to find the required setting.
-gary
The data breakpoint setting doesn't know the type of variables - just the address. There's a field in that dialog to indicate the number of bytes to watch.
In other aspects of actual debugging, it does know the type.
