How do disable - enable a contol?
reidar
New User
I am programming a windows application. In a dialogue (modeless) I want to disable/enable controls dependent about defined conditions..
Can anybody advise?
andrew_4619
use ifwin, only: GetDlgItem, EnableWindow, ShowWindow, SW_SHOW, SW_HIDE, TRUE, FALSE, handle, bool
implicit none
integer (bool) :: bret
integer handle :: hwnd, hdlg
hwnd = GetDlgItem(hDlg, ID_CONTROL)  ! get control handle using dialog handle and control index
bret = EnableWindow(hwnd,  TRUE )    ! enable control
bret = EnableWindow(hwnd,  FALSE )   ! disable control
bret = ShowWindow( hwnd, SW_SHOW )  ! make control visible
bret = ShowWindow( hwnd, SW_HIDE )  ! make control invisible
LRaim
This is an example from VS Help:
BOOL CMyFileDialog::OnInitDialog()
   CFileDialog::OnInitDialog();
   CWnd* pWndParent = GetParent();
   //make sure you add #include <dlgs.h> for IDs 'edt1' & 'stc3'
   //disables the 'file name' edit and static control
   //of the standard file open dialog
   //get handle of 'file name' combobox control & disable it
   CWnd* pWnd = pWndParent->GetDlgItem(cmb13);
   pWnd->EnableWindow(FALSE);
   //get handle of 'file name' static control & disable it
   pWnd = pWndParent->GetDlgItem(stc3);
   return TRUE;
reidar
New User
Thanks Luigi,
I forgot to mention  that I am writing in Visual Fortran ...Have not the possibility to apply other languages :-(
andrew_4619
Is this a quickwin (iflogm) or a windows api dialog? The answer would be different for each.
reidar
New User
It is a windows application, not quickwin..
Best regards
LRaim
If you have created a modeless dialog with its controls using fortran it should be simple to call the 'EnableWindow()' function using Fortran syntax. System calls do not change with language.
andrew_4619
implicit none
