How do you plot a bitmap?
Intel_C_Intel
I have displayed a bitmap on the screen using the StretchBlt command.
I now want to send the bitmap to an HP plotter using HP RTL commands. Has anyone done this and has an example of how to do it?
I have sent lines to the HP plotter using SP,PU & PD HP-GL commands in the past
David
Jugoslav_Dujic
Valued Contributor II
Mhm, I'm not quite familiar with that plotter stuff, but GDI is supposed to encapsulate HP-GL if appropriate driver is present. The printing routines (GDI) I wrote once did work flawlessly on HP and Epson plotters too.
Take a look at XFTGDI. Does it work on a plotter? (Take care not to specify large paper format - if you forget, send me the paper so I can use it as an ad poster :-))
Intel_C_Intel
I looked at your code and documentation - but couldn't see anything about plotting a bitmap.
I want to write to a file using HP commands, then send the file to the plotter.
David
Jugoslav_Dujic
Yes, my point was that you can treat the plotter as a printer and do a StretchBlt to its DC (XPlaceBitmap and XBitCopy are wrappers around StretchBlt). However, if you really have to write to file using HP-GL, well... you're on your own.
Jugoslav
Intel_C_Intel
Looks as if I'm on my own, unless anyone else can help.
I wanted to use HPGL commands as that is how I plot my vectors.
I could change all my plotting... but not yet.
David
durisinm
You may be able to OPEN the plotter as a file with FILE='network_address', where network_address is in the form serverprinter (assuming this is a Windows network). After that, use WRITEs or PRINTs to send your HPGL commands to the plotter one at a time. CLOSE the "file" once you're done plotting.
I seem to recall doing something similar once, but it's been a while.
Mike
If your program uses a graphics language such as HP-GL, look at Fortran_WinprintDirect.f90
Steve
Intel_C_Intel
Steve,
Thanks for the reply.
But how do I use this to plot a bitmap.
Do you have an example of the call.
The first parameter is a unit - a file - this cannot be the bitmap?
David
You said that in the past you sent HP-GL commands to the plotter. Well, I told you how you can send HP-GL commands - you write them to a file and then call the routine in Fortran_WinPrintDirect.
If you want to render a bitmap to a page and print that, I don't have ready code for that purpose. If you look at the Win32 SDK documentation on using printers, there is a C sample that prints a bitmap - if you study that and look at Fortran_WinPrint, you should be able to work it out.
Steve
Intel_C_Intel
Sending the file to the plotter is not a problem.
The problem is creating the HP-GL file from the Bitmap.
David
ralphbaird
Just dropping in to say I have been greatly disappointed with the response you were getting from Intel. I have the same need and I have been unable to get the info I need. I want to write files in HP-RTL to go direct to large format HP DesignJet plotters. I typically have 42 inch by severa feet plots. HP and Intel have been no help.
If you get this reply, let me know.
Ralph Baird
Houston Texas [email protected]
Ralph,
I'm sorry to hear you are disappointed in Intel's support, but our technical support does not extend to tutorials on programming.
I don't know HP-RTL, but if it is anything like HP-GL, in that it is a series of text commands, the Fortran-WinPrintDirect.f90 example code should do what you want.
mwehle
The Link Fortran_WinprintDirect.f90is not true. Please post the correct one.
anthonyrichards
New Contributor III
How do you create the bitmap? If you draw it on a device context, then you must use drawing commands.
Why not, for each drawing command, duplicate its equivalent in HP-GL commands, or wahtever,at the same time and copy them to a file?
Or how about trying SPLOT, see here http://www.swplot.com/splot.htm?
(P.S. I have no experience of it, but it came up when I used Google to search fro 'HP RTL'.
Jugoslav_Dujic
Google is your friend:
