29653 Discussions
How does a program react if SSE2 is not supported by the CPU
rwg
I execute a program on an old PC with an AMD Athlon XP 1.1 GHz (Palomino). My program causes an exception (Code 0xc000001d = STATUS_ILLEGAL_INSTRUCTION) on this PC at the statement
IWERT=NINT(DWERT)
On dozens of other PCs the program works fine.
The sytem requirements for Intel Fortran says that the hardware has to support SSE2. The AMD Athlon XP 1.1 GHz (Palomino) does not support SSE2. Is this the reason forthis program exception?
The compiler itself requires that you install and do the build on a system that supports SSE2 instructions. For execution, the default is to also require SSE2, but you can specify /arch:ia32 to generate code that will work on a PC that has an Intel Pentium or compatible processor.
bendel_boy1
Quoting - rwg
IWERT=NINT(DWERT)
I've had similar error messages - essentially, if your program uses a processor extension that is not supported on that particular machine then the program will crash. You can complain to thesupplier & see if they wil supply a derated version of the program.
