How to Diagnose "impossible" crash
bbradley
In Windows 10, with Visual Studio 2017 and Intel® Parallel Studio XE 2019 Update 5, the following code crashes on the last line.
Here is a bit of the code:
      Character ENTDT*8
c --- (process to generate ENTDT here)
      ENTDT = '30120331' ! Ignore process
      Write (AString,'(2a)') ' The Date=', ENTDT
      Call WINMSG (AString)
      Read (ENTDT, '(i4,2i2)', IoStat = i ) iYear, Imonth, Iday
The output line written to a diagnostic file via the WINMSG function yields the following output:
"  The Date=30120331"
The crash "site" appears as shown in the attached file, ENTDT-2.png, and the line 1040 is the Read statement shown above. The crash does not seem to make sense because we are reading 8 characters, and that is what the format statement says.
How can the cause of this problem be diagnosed ? (Sure looks like the same type of problem reported by Bart Jackson).
P.S. To Dr. Fortran: Source code was submitted to Support over a month ago, waiting for a reply. Can't put the code here as it is also *private*.
Steve_Lionel
How are iYear, iMonth and iDay declared? If any of them are arrays, you'd get this behavior.
Can you construct a small, self-contained test case that shows the problem? It should be easy based on what you showed above. Often the attempt to do so reveals that the real problem is elsewhere.
Ferdinand_T_
New Contributor II
Steve Lionel (Ret.) (Blackbelt) wrote:
[...] Often the attempt to do so reveals that the real problem is elsewhere.
In support of Steve's comment: The attached image shows a runtime IO-error message, but the suspected read-statement specifies iostat which ought to supress such messages. Unless, of course, the error-message is generated errorneously, indicating a bigger compiler-issue.
GVautier
New Contributor III
Neels
New Contributor II
I often get it lately that the program just shuts down. It usually is a write statement with an error in the format. Even including an error statement number to (ie err=250) and iostat it still happens. I have learnt by now to make sure that the format is correct. With error I mean something like trying to write an I4 where the format is I3.
jimdempseyatthecove
Place a break point on the offending Read. Then from the debugger, tell us all about the variables: i,  iYear, Imonth, Iday
This includes type and prior contents.
Jim Dempsey
jimdempseyatthecove
Additionally, if you comment out the call to WINMSG does the error occur?
If NOT, then you have an interface declaration error or omission.
Jim Dempsey
Igor_V_Intel
This also happens in the code with no call to WINMSG. I have created a reproducer:
SUBROUTINE EXPIRY_DATE ( IYEAR, IMONTH, IDAY )
CHARACTER ENTDT*8
INTEGER I
INTEGER IYEAR, IMONTH, IDAY
ENTDT = '30120331'
READ (ENTDT, '(I4,2I2)', IOSTAT = I ) IYEAR, IMONTH, IDAY
END SUBROUTINE EXPIRY_DATE
PROGRAM TEST
CALL EXPIRY_DATE
END
bbradley
Thanks to all for your comments. Support has just confirmed that this problem will be "escalated" to be fixed.
Here is a short demo as provided by IGOR:
CHARACTER ENTDT*8
INTEGER I
ENTDT = '30120331'
PROGRAM TEST
CALL EXPIRY_DATE
END
GVautier
New Contributor III
Call and subroutine arguments does'nt conform. How can this ever work?
Igor_V_Intel
That is not a valid code since I didn't pass arguments to a subroutine. The code that fails in the application looks like this:
Subroutine EXPIRY_DATE ( iYear, Imonth, Iday )
!MS$ATTRIBUTES DLLEXPORT :: EXPIRY_DATE
character ENTDT*8
integer i
integer iYear, Imonth, Iday
ENTDT = '30120331'
end subroutine EXPIRY_DATE
program test
call EXPIRY_DATE (iYear, Imonth, Iday)
end
This small test doesn't show a problem. Note that it is reproducible with /Od optimization level (disabled). I will continue to work on the full project to find a smaller reproducer.
GVautier
New Contributor III
The fact that optimization level change the behaviour may signify that the source of the problem is probably a stack corruption elsewhere in the program.
Igor_V_Intel
The execution goes further if I split the read statement to 2:
      Read (ENTDT, '(i4)', IoStat = i ) iYear
      Read (ENTDT, '(2i2)', IoStat = i ) Imonth, Iday
 However, it then fails on similar read statement later:
Character Ch4*4
real x
ENTDT = '30120331'
Ch4='6.1'
Read (Ch4,'(f4.0)')
Igor_V_Intel
The optimization level doesn't change the behavior. In this case it is compiler with Od (optimization disabled).
Full compiler options list:
ifort test.f90 /nologo /debug:full /Od /fpp /f77rtl /fpscomp:filesfromcmd /fpscomp:ioformat /fpscomp:logicals /fpscomp:general /warn:declarations /warn:unused /align:rec4byte /align:commons /names:uppercase /iface:stdref /iface:mixed_str_len_arg /traceback /check:bounds /check:uninit /libs:static /threads /dbglibs /c
GVautier
New Contributor III
This kind of "impossible" error is generally symptomatic of a stack corruption elsewhere.
Igor_V_Intel
Yes, it looks like a stack corruption. I have found that for the exception with Read (Ch4,'(f4.0)') the value of Ch4 is garbage, as well as iteration variable and many other vars.
