29390 Discussions
How to build separated DLLs which interact with each other
olmak
Hi, I have to build two separated DLLs in Visual Fortran which import functions from each other. Thus, building the first DLL requires the .lib file of the second DLL and building the second DLL requires the .lib information of the exported functions of the first DLL. But since I have no .lib file at the beginning I am not able to build any of these DLLs because I get an unresolved symbol error message for the functions which are located in the other DLL. How do I solve this problem?
Jugoslav_Dujic
Valued Contributor II
Best, redefine it :smileyhappy:. If you can manage to pass one procedure to another dll as an argument, that will probably be the best. Or you can use LoadLibrary->GetProcAddress to load the other dll at run-time (search the Forum or see LOADEXP sample).
If neither is applicable, you can resolve the vicious circle by using a manual build. DLLEXP1 sample demonstrates that -- see this thread(but I'm not familiar with details).
Jugoslav
olmak
Thank you very much for your help!
