29390 Discussions
How to call a dll (built by fortran) in Fortran?
lyricx
I tried the following example, but didn't succeed.
I am not familar with how to call a dll. what is the problem with my calling?
some one can give some help? thanks!
!----- the main program calling a dll
PROGRAM DLLTEST
IMPLICIT NONE
INTERFACE
SUBROUTINE ARRAYTEST (sarray)
!DEC$ ATTRIBUTES DLLIMPORT:: ARRAYTEST
REAL(4) sarray(3, 7)
END SUBROUTINE ARRAYTEST
END INTERFACE
REAL(4) sarray(3,7)
CALL ARRAYTEST(sarray)
WRITE(12,*) sarray(:,:)
END PROGRAM DLLTEST
! --------- the program used for generating a dll
! ARRAYtest.f90
! FUNCTIONS/SUBROUTINES exported from ARRAYtest.dll:
! ARRAYtest - subroutine
SUBROUTINE ARRAYTEST(arr)
!DEC$ ATTRIBUTES DLLEXPORT :: ARRAYTEST
REAL(4) arr(3, 7)
INTEGER i, j
DO i = 1, 3
DO j = 1, 7
arr (i, j) = 11.0 * i + j
END DO
END DO
END SUBROUTINE
lyricx
when I compile the main program, the error is:
dlltest error LNK2019: unresolved external symbol __imp__ARRAYTEST referenced in function _MAIN__
dlltest fatal error LNK1120: 1 unresolved externals
it seems that the main program can't recognize the dll.
something wrong with my implementation?
anthonyrichards
New Contributor III
Did you include the DLL's export library ARRAYTEST.LIB in your project when building your test program?
lyricx
solved,
it is successful when deleting " !DEC$ ATTRIBUTES DLLIMPORT:: ARRAYTEST".
Then you are not linking to the DLL export library and probably not using the DLL.
