How to comment region ?
maxgreenberg
I did not succed to realize how to comment the whole region in the Compaq Visual Fortran ?
I hope somebody can help me, thanks in advance.
Intel_C_Intel
!DEC$ If(.False.)
!DEC$ End If
Sabalan.
Well, that's not a comment, that's conditional compilation. If what you want is to disable a section of code, that's fine, but I wouldn't use it for commenting.
Fortran does not have block comments.
Steve
david_jones
There is some code in the sample IDE macros that needs to be modified to work for Fortran. The attached is a cut-down and revised version ... you would need to check that it identifies free/fixed format to suit your usage. The macros usually live in....
C:Program FilesMicrosoft Visual StudioCommonMSDev98Macros
David Jones
