29423 Discussions
How to compile with previous version?
mr_sceptical
I am trying to compile some code, written by someone else, using Ifort on Ubuntu. The code does not compile using Ifort 12.0, but does with 9, 10 etc. I have tested with on a 64-bit system using Ifort 11, but wish to build the code for my 32 bit system.
Whilst I appreciate fixing the code so it will compile with 12.0 would be ideal, compiling with an older compiler would be a convenient work around.
Is it possible to either download previous versions, or run the current version in a 'Ifort 10' type mode?
Many Thanks
Tom
You can download and install a previous version - see this article. What are the errors?
mr_sceptical
Steve. That's perfect. Thanks.
