29284 Discussions
How to convert an O file to fortran source file
Vahid_E_
Hi all,
I have received from somebody else a Fortran object file (created under Linux). Can I convert it back to the source file? (I have Windows 7)
andrew_4619
No you need the original source file (.for / .f90) , the o file is the compiled binary code.
mecej4
A tool that does this is called a "decompiler". As far as I know, in practical terms, especially if the object file was produced by an optimizing compiler or the -g compiler was not used, there is no such tool.
Arjen_Markus
The best you might hope to achieve is to convert it to assembly code and as that is rather platform-dependent, you would have to figure out from that code what is really going on. It would be much easier to reprogram the thing if you know what it is meant to do.
Andrew_Smith
Valued Contributor I
No you can not
jimdempseyatthecove
An alternative question might be can you convert the Fortran Linux built .o file into a compatible Fortran Windows build .obj file. It might be possible to do this, but you may need to add helper functions if the calling conventions differ. Other than that, it is reverse engineering from the assembly code.
Jim Dempsey
