29607 Discussions
How to *create* an optional argument inside a subroutine
OP1
New Contributor III
Hi!
The title of this threadmay seem a bit obscure. I want to do the following:
SUBROUTINE S2(D)
REAL,INTENT(IN),OPTIONAL :: D
... do some stuff here...
END SUBROUTINE S2
And:
SUBROUTINE S1(A,B)
REAL,INTENT(IN) :: A
REAL,INTENT(IN),OPTIONAL :: B
REAL C
IF (PRESENT(B)) THEN
C=B+1
ENDIF
CALL S2(C)
ELSE
CALL S2
ENDIF
END SUBROUTINE S1
If there are many calls to S2, I need to repeat many times the IF construct that checks for the presence of B. Is there a way to make the declaration of C *disappear* if the argument B is not provided? In which case I would only need to call S2(C), whether C exists or not.
In other words: passing C to S2 is contingent upon the presence of the optional argument B, and I don't want to have to write the IF construct (if there is another way to do this, of course) every time I call S2.
Thanks for your help regarding this unusual question,
Olivier
jimdempseyatthecove
Olivier,
When S2 is making the many calls to S1, then simply pass the optional arg
C=B+1
ENDIF
CALL S2(C)
This requires S2 to have C be pass by reference. Fortran permits passing a missing optional arg in a call.
You may also want to look in the documentation under Generic Interface to see how the same named "subroutine" can call one of several other named subroutines.
Jim Dempsey
OP1
New Contributor III
Olivier,
C=B+1
ENDIF
CALL S2(C)
Jim Dempsey
I am afraid I didn't explain very well what I wanted. In the example above, S2 will stillhave the argument C passed to it when B is not present. In which case the value in C has no meaning and S2 should certainly not use it.
In other words:
If B is present, call S2 with the updated value of C.
If B is absent, call S2 without C.
I can't see a way to do this without a IF construct... maybe somebody has a better idea.
Olivier
I don't know of a way to do that. The only thing I can offer is that if you call S2 with B, the "omitted-ness" of B gets passed along to S2. Make sure that explicit interfaces are visible to the callers of any routine with an OPTIONAL argument.
OP1
New Contributor III
Thanks Steve. That's what I suspected - but couldn't be sure of. I'll stick to the IF constructs, no matter how inelegant (and tedious) this is. This is still doable with one or two optional arguments - but become quickly an untractable combinatorial issue for more.
It would be nice if there was a way in Fortran to make a variable definition *disappear* from within a subroutine, so that it becomes invisible to subroutines that accept optional arguments (if necessary):
SUBROUTINE S1(A,B)
INTEGER,INTENT(IN) :: A
INTEGER,INTENT(IN),OPTIONAL :: B
INTEGER,OPTIONALIZABLE :: C
INTERFACE
SUBROUTINE S2(X)
INTEGER,INTENT(INOUT),OPTIONAL :: X
...do some work here...
END SUBROUTINE S2
END INTERFACE
C = C+1
ELSE
HIDE(C)
ENDIF
CALL S2(C)
SHOW(C)
WRITE(*,*) C
END SUBROUTINE S1
Maybe this will happen in Fortran 2013 :) ...
Olivier
No chance of that - Fortran 2013 may not have any new features at all if some members of the committee get their way (and I would agree.) However, consider this:
[plain]subroutine s1 (b,c)
real, optional :: b,c
if (present(b) .and. present(c)) then
  c = c + 1
  end if
call s2(c)
end subroutine s1[/plain]
You'd just have to know that if you call s1 with b you also have to pass c, and if b is not passed, don't pass c. (You could add protective code in s1 to check for that.)
