29607 Discussions
How to define an operator for a self-defined type data
Port__Phillip
Hi, everyone:
I would like to define an adding operator for a self-defined type data structure named "test_class"
Its defination is listed below
module test_class
implicit none
type vector
    integer n1
    real*8, allocatable :: v (:)
end type vector
interface operator (+)
    module procedure add
end interface
contains
function add (a1, a2)
implicit none
type (vector) add
type (vector), intent (in) :: a1, a2
add%v = a1%v+ a2%v
end function add
end module test_class
And the main program part is
program test1
use test_class
implicit none
type (vector) a1, a2, a3
a1%n1 = 3
a2%n1 = 3
a3%n1 = 3
allocate (a1%v(a1%n1), a2%v(a2%n1), a3%v(a3%n1))
a1%v = 3.0d0
write (*,*) a1%n1, a1%v
a2%v = 2.0d0
a3%v = 3.0d0
a1 = a2+ a3
end program test1
The output could sometime go wrong, with a1%n1 alternated and segmentation error is reported.
What is the problem? How to define an operator in Fortran for a type data structure?
FortranFan
You may want to review references in this Dr Fortran blog: https://software.intel.com/en-us/blogs/2013/12/30/doctor-fortran-in-its-a-modern-fortran-world
specifically the sections of kind and length-type parameters, parameterized derived types (PDTs), type-bound procedures, modern Fortran style and usage, and so forth.
Since a PDT attempt caused an 'internal compiler error (ICE)', here's a sample with an allocatable component along the lines of what you show in the original post you can review:
module mykinds_m
   use, intrinsic :: iso_fortran_env, only : WP => real64
   implicit none
end module mykinds_m
module test_class
   use mykinds_m, only : WP
   implicit none
   type :: vector
      integer :: n1
      real(kind=WP), allocatable :: v(:)
   contains
      private
      procedure, pass(a1)  :: add_vector
      generic, public :: operator(+) => add_vector
   end type vector
contains
   function add_vector(a1, a2) result( sum_v )
      class(vector), intent(in) :: a1
      type(vector), intent(in)  :: a2
      !.. Function result
      type(vector) :: sum_v
      if ( a1%n1 == a2%n1 ) then
         sum_v%n1 = a1%n1
         sum_v%v = a1%v+ a2%v
      else
         ! appropriate action elided: error stop?
      end if
      return
   end function add_vector
program test1
   use test_class, only : vector
   implicit none
   type(vector) :: a1, a2, a3
   a1%n1 = 3
   a2%n1 = 3
   a3%n1 = 3
   a1%v = 3.0_wp
   a2%v = 2.0_wp
   a3%v = 3.0_wp
   a1 = a2 + a3
   stop
end program test1
Upon execution with Intel Fortran,
 3 3.00000000000000 3.00000000000000 3.00000000000000
 3 5.00000000000000 5.00000000000000 5.00000000000000
FortranFan
module mykinds_m
   implicit none
module test_class
   implicit none
   type :: vector
      integer :: n1
   contains
      private
   end type vector
contains
      !.. Function result
         sum_v%n1 = a1%n1
      else
      end if
      return
program test1
   implicit none
   a1%n1 = 3
   a2%n1 = 3
   a3%n1 = 3
   a1%v = 3.0_wp
   a2%v = 2.0_wp
   a3%v = 3.0_wp
   a1 = a2 + a3
   stop
end program test1
Port__Phillip
Thank you for your kindly reply.
I have tried the codes.
But it seems can not be compiled with the error:
error #6355: This binary operation is invalid for this data type.   [A2]
error #6355: This binary operation is invalid for this data type.   [A3]
error #6549: An arithmetic or LOGICAL type is required in this context.
The error is pointing to the 19th line in the file for program test1.
The compiling enviroment is Windows 10 with Microsoft Visual studio and Intel Fortran compiler.
How can I fix it?
FortranFan
Checked whether the test_class module was recompiled with the code in Message #2 and the updated mod file is use'd when the main program is being compiled.
By the way, you may want to use the Intel Fortran Windows forum given your Windows 10 OS and Visual Studio environment; this forum is for Linux and Mac OS.
Philip, I tried FortranFan's example and it compiled and ran fine.
FortranFan, would you please attach the PDT version that got you an ICE?
FortranFan
Steve Lionel (Intel) wrote:
.. FortranFan, would you please attach the PDT version that got you an ICE?
Steve,
Here it is:
module mykinds_m
   implicit none
module test_class
   implicit none
   type :: vector(n1)
      integer, len :: n1
      real(kind=WP) :: v(n1)
   contains
      private
   end type vector
contains
      class(vector(n1=*)), intent(in)    :: a1
      type(vector(n1=a1%n1)), intent(in) :: a2
      !.. Function result
      type(vector(n1=a1%n1)) :: sum_v
      sum_v%v = a1%v + a2%v
      return
program test1
   implicit none
   type(vector(n1=3)) :: a1, a2, a3
   a1%v = 3.0_wp
   a2%v = 2.0_wp
   a3%v = 3.0_wp
   a1 = a2 + a3
   stop
end program test1
Compilation details:
C:\..>ifort /c /standard-semantics /warn:all /stand mykinds.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R
) 64, Version 17.0.1.143 Build 20161005
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
C:\..>ifort /c /standard-semantics /warn:all /stand test_class.f90
C:\..>ifort /c /standard-semantics /warn:all /stand test1.f90
010101_14277
catastrophic error: **Internal compiler error: internal abort** Please report th
is error along with the circumstances in which it occurred in a Software Problem
 Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for test1.f90 (code 1)
Port__Phillip
Thank FtranFan adn Mr. Lionel for your time and kindly reply
FortranFan
@Phillip P.,
By the way, if your code design for 'vector' and n1 variable implies dimensions and if there is a fixed small set you are planning to work with, as in 1-D, 2-D, 3-D, etc., then you may want to look into 'kind type parameters' as I mention in Message #2.  With PDTs, it is easier for implementations to get the kind type working and you can then have efficient and expressive code working without an ICE in Intel Fortran as follows:
module test_class
   implicit none
   type :: vector(n1)
      integer, kind :: n1
   contains
      private
      procedure, pass(a1)  :: add_vector_1
      procedure, pass(a1)  :: add_vector_2
      procedure, pass(a1)  :: add_vector_3
      generic, public :: operator(+) => add_vector_1, add_vector_2, add_vector_3
   end type vector
contains
   function add_vector_1(a1, a2) result( sum_v )
      class(vector(n1=1)), intent(in) :: a1
      include 'add.f90'
   end function add_vector_1
   function add_vector_2(a1, a2) result( sum_v )
      class(vector(n1=2)), intent(in) :: a1
      include 'add.f90'
   end function add_vector_2
   function add_vector_3(a1, a2) result( sum_v )
      class(vector(n1=3)), intent(in) :: a1
      include 'add.f90'
   end function add_vector_3
include file 'add.f90'
      !.. Function result
      return
program test1
   implicit none
   type(vector(n1=3)) :: a2
   type(vector(n1=3)) :: a3
   a1%v = 3.0_wp
   write (*,*) "a1%n1 = ", a1%n1, ", a1%v = ", a1%v
   a2%v = 2.0_wp
   write (*,*) "a2%n1 = ", a2%n1, ", a2%v = ", a2%v
   a3%v = 3.0_wp
   write (*,*) "a3%n1 = ", a3%n1, ", a3%v = ", a3%v
   a1 = a2 + a3
   write (*,*) " after addition:"
   blk: block  ! uncomment the two lines below and see what happens!
      !type(vector(n1=1)) :: b1
      !b1 = a2 + a3
   end block blk
   stop
end program test1
 a1%n1 =  3 , a1%v =  3.00000000000000 3.00000000000000
 3.00000000000000
 a2%n1 =  3 , a2%v =  2.00000000000000 2.00000000000000
 2.00000000000000
 a3%n1 =  3 , a3%v =  3.00000000000000 3.00000000000000
 3.00000000000000
  after addition:
 a1%n1 =  3 , a1%v =  5.00000000000000 5.00000000000000
 5.00000000000000
FortranFan, thanks for the ICE example. I can reproduce this in 17.0.1 but not in our internal builds for the next update, so perhaps it has been fixed.
Port__Phillip
Thank you FortranFan for your recently example.
It helps me a lot to further simplify my code.
