I am trying to download the Fortran Compiler for Linux using FTP. I am
using a secure conection (SSH) to one of our remote Linux machines and
from there I would like to download the zip/tar file. The procedure
should be also the same from Windows.
In your web page the FTP address of the file is:
ftp://download.intel.com/software/products/compilers/
downloads/l_fc_c_9.1.036.tar.gz
Hence, I try:
I would appreciate help about this matter,
Thanks in advance, Javier
Hence, I try:
ftp> open download.intel.comWhile I can open ftp://download.intel.com, I am not able to login using my current login and password (the one I typically use to log in your web page). I do not know what I am doing wrong? I do not understand how I can download the file using my web browser, but not using FTP.
Connected to download.cps.intel.com.
220 Microsoft FTP Service
500 'AUTH GSSAPI': command not understood
500 'AUTH KERBEROS_V4': command not understood
KERBEROS_V4 rejected as an authentication type
ftp> user
(username) mylogin
331 Password required for mylogin.
Password: mypassword
530 User mylogin cannot log in.
Login failed.
The FTP server supports anonymous FTP only. There is no shell access. Log in as "anonymous" with your email as the password.
However, I would recommend instead that you download from the Intel Registration Center, as that's where you'll find more up-to-date compilers.
Thank you it is working now. I will try to use the Intel Registration
Center in the future. However, I will probably need an FTP link since I
can only use the console.
Javier
Javier
Unfortunatelty, FTP access is offered only for the initial version of the compiler - updates are through the Registration Center only.
