29386 Discussions
How to express a long directive for openMP in Fortran?
Anonymous21
How do you know how to express the continuous red line with the previous line as follows?
!$OMP PARALLEL DEFAULT(PRIVATE),SHARED(i, j,k,ucn,q,dc,de,dz)
!$OMP& SHARED(qq,qw
) ---> Question??
!$OMP END PARALLEL
If adding the + or &, the complier make the error message.
adi.f90(10): error #5082: Syntax error, found '&' when expecting one of:
Ricardo is close. OpenMP directives may be continued and the syntax for doing so is similar to that for Fortran free-form source. The directive to be continued shall have an & as the last non-whitespace character. The continued directive may (but does not require) have an & after the !$OMP introducer. Note that the ! is required - Ricardo left it out, probably accidentally.
So what you want is this:
[plain]!$OMP PARALLEL DEFAULT(PRIVATE),SHARED(i, j,k,ucn,q,dc,de,dz), &
!$OMP& SHARED(qq,qw) [/plain]
The comma between clauses is optional, but I think for style you should be consistent as to whether you use it or not.
rreis
Reading from here: https://computing.llnl.gov/tutorials/openMP/#Directives
I would suppose, if this is freeform fortran that
$OMP BLABLA &
$OMP BLABLA2
would be the right way...
(infering from "All Fortran free form rules for line length, white space, continuation and comment columns apply for the entire directive line")
rreis
yep, thanks for the correction! :)
Anonymous21
Thanks for Ricardo and Steve's help.
Quoting - hydrol88
!$OMP& SHARED(qq,qw
) ---> Question??
!$OMP END PARALLEL
lessonfree
How many lines you can create in such manner? Is it any kind of limitations?
TimP
Quoting - lessonfree
I've never seen a limitation reached, even with the use of default(none) in large parallel regions, requiring over 100 variables in the shared and private lists.
lessonfree
Quoting - tim18
lessonfree
Is it described in documentation somewhere?
TimP
That would be the OpenMP specification, which you could re-examine at will.
I don't know for sure, but I'd expect that the Fortran 90 standard minimum of 39 free-form continuation lines to be relevant. The Intel compilers allow 511 continuations.
