How to get Intel 8.x compiler (needed for legacy Fortran code)
christoph_s_1
Hello!
I need the old Intel compiler for some old Fortran code that no longer works with the newer compilers. Intel 8.x compiler is explicitly recommended for the code I am trying to compile.
How do I get the Intel 8.x compiler? As a student, I have access to the Intel Parallel Studio XE Cluster Edition for Linux. Under "Additional downloads, latet updates and prior versions", I can also download older versions of this, going back to 2013. But I don't find any option on the website on how to download just an older compiler.
Thank you for your help.
Steven_L_Intel1
Student licenses don't go that far back. Version 8.0 is from 2004 and was VERY buggy - I cannot in good conscience recommend it to anyone. Show us the problems you're having with the current version and we'll be glad to help. I can't think of any reason why an old compiler would be needed. It may simply be that the source you're using has errors that are detected by newer versions.
christoph_s_1
Thank you for your reply.
As it turns out, I was able to compile the program with the latest compilers. The previous fault was, in truth, with MPICH which I hadn't properly linked to the Intel compilers.
