29314 Discussions
How to get a file length in ifort 8.1?
ncwerons
I need to check length of a file after opening it in my code written in F77. Can I do it using just one procedure like NFSIZE() in MS FORTRAN or FILESIZE() in WATCOM FORTRAN? I learned I could use the procedure GETFILEINFOQQ() but it seems to me a little complicated. Is there any simpler way?
Pawel
user1
CHARACTER FILE_NAME*128
INTEGER*4, EXTERNAL :: STAT
INTEGER*4 STATB(12), IS, FILE_LEN
IS = STAT ( FILE_NAME, STATB )
IF ( IS .NE. 0 ) THEN
! Error message ...
END IF
FILE_LEN = STATB(8)
Enjoj!
Leonid
P.S. You may need -Vaxlib option for linking
