29389 Discussions
How to get size of file in Intel Fortran?
brb36641
Some one give me any idea to solve this issue, please.
I wonder that Intel Fortran should recommend how to check size of file in source code.
e.g. INQUIRE and some specifier of it
My idea is recl specifier of INQURE. I attempt to use it.
Actual sorce code
integer record-length
INQUIRE(file='st-file',recl=record-lenght)
write (*,*) 'st-file length',record-lenght
Then the last 'write' uncorrect size of st-file.
What's wrong? Please let me know how to solve.
File length is not record length. All INQUIRE (RECL=) will tell you is the value used in an OPEN to open a current unit. Otherwise no value is available.
What you want is GETFILEINFOQQ.
brb36641
Hi, Thank you , Steve.
Let me ask you one further question.
Will GETFILEINFOQQ workin Conpaq Fortran as same as in Intel Fortran?
Yes, exactly the same. If you want your source code to work with both compilers, use USE DFLIB to make the routine available.
brb36641
Dear Steve,
Thank you very much for helpful suggestion.
My problem was immediately solved by your favor.
Thank you again.
