29487 Discussions
How to improve calculation speed on virtual machines for Exe compiled by Intel Fortran XE2011?
gqxsun
We experience slow calculation speed on virtual machines with use of Exe compiled by Intel Fortran XE2011.
The application was for pure numerical calculation which has many do-loops and subroutines. There was no graphics or C or C++ involved.
Our facilities and compiled Exe:
Local desktop PC
(LDP)
Intel i5-2400 CPU @3.10 GHz, 4 GB RAM, 32 bit operation, Window 7 service pack 1
host machine of virtual machines
8 processors
virtual machine
(VM)
Intel i7-920 @2.7 GHz, 1 processor, 1GB Ram, 64 bit operation, window XP 2003 service pack 2
32xC.exe
by CVF ver 6.6
32xI.exe
64xI.exe
by Intel XE 2011 on the local PC with options of 'Maximize Speed', 'stack reserve size=10M', 'stack commit size=10M', /Qimf-arch-consistency:true /Qprec
CPU comparison (sec)
32xC.exe
32xI.exe
64xI.exe
LDP
1145
458
VM
1717 (stable)
630-2498 (not stable and slow sometimes)
547-1868 (not stable and slow sometimes)
May we know what was the reason and how to solve the problem?
jimdempseyatthecove
What is the RAM size of the Host machine of virtual machines?
What is the processor model of the Host machine of virtual machines?
What is running on the Host machine of virtual machines while you are running your test program?
On the Host machine of virtual machines, can your run the performance monitor (not as a virtual machine, rather as a host application)? If you can, monitor page faults (aka swapping, paging). Make repeated runs, you see if you notice a corilation between number of page faults (during run) and run time of test program.
An additional source for "not stable" (inconsistent run times) is cache eviction. This can be caused between applications as well as between threads within an application (VTune might help you identify the cause).
Jim Dempsey
