29386 Discussions
How to initialize a dialog box in a Fortran .dll file
lyricx
In main program, I called a subroutine in a Fortran .dll file to initialize a dialog box, but the initialization failed:
StartDlg = DlgInit(IDD_DIALOG5, XDlg)
How to settle this problem?
anthonyrichards
New Contributor III
That's because you have to use DLGINITFRONRESOURCEHANDLE when the dialog is in a DLL. If your dll is called 'mydll.dll', use
INTEGER Hinst, iret
type (dialog) dlg
Hinst=GetModuleHandle('mydll.dll'C)
iret=DlgInitwithResoureHandle(IDD_DIALOG,Hinst, dlg)
From the Help:
"DLGINIT, DLGINITWITHRESOURCEHANDLE
Run-Time Functions: Initialize a dialog box.
Module: USE DFLOGM
Syntax
result = DLGINIT (id, dlg)
result = DLGINITWITHRESOURCEHANDLE (id, hinst, dlg)
id
(Input) INTEGER(4). Dialog identifier. Can be either the symbolic name for the dialog or the identifier number, both listed in the Include file (with extension .FD).
dlg
(Output) Derived type DIALOG. Contains dialog box parameters.
hinst
(Input) INTEGER(4). Module instance handle in which the dialog resource can be found.
Results:
The result is of type LOGICAL(4). The result is .TRUE. if successful; otherwise, the result is .FALSE..
DLGINIT must be called to initialize a dialog box before it can be used with DLGMODAL, DLGMODELESS, or any other dialog function.
DLGINIT will only search for the dialog box resource in the main application. For example, it will not find a dialog box resource that has been built into a dynamic link library.
DLGINITWITHRESOURCEHANDLE can be used when the dialog resource is not in the main application. If the dialog resource is in a dynamic link library (DLL), hinst must be the value passed as the first argument to the DLLMAIN procedure"
lyricx
I used this method to initialize the dialog in my .dll file, but the initialization still failed. Confused!
anthonyrichards
New Contributor III
If you want help, you must post your initialisation code. You should also look at the handle returned by GetModuleHandle to see if it is non-null. When generating the DLL containing your dialog(s), you must also INCLUDE 'RESOURCE.FD' which the resource compiler generates to containthe definitions of your dialog box identifiers (IDD_DIALOG1, etc.) as PARAMETERS.
