How to let the program output runtime error information in C++ code?
Zhanghong_T_
Dear all,
I have the C++ dynamic linked library built by VS2012+Intel C++ 14.0, the dynamic linked library is called by Fortran main program.
Currently there are some problems in the C++ code and I need to locate it. However, the bug can't be reproduced in Debug mode but in Release mode, I can't get to know where the crash happened. I have set /Zi option in 'C/C++' and /DEBUG option in 'Linker', but the output message is as follows:
forrtl: severe (157): Program Exception - access violation
Image              PC                Routine            Line        Source
CSGlib.dll         000007FEEF57DF1E  Unknown               Unknown  Unknown
CSGlib.dll         000007FEEF57DB5F  Unknown               Unknown  Unknown
CSGlib.dll         000007FEEF57D78D  Unknown               Unknown  Unknown
fem.exe            000000013FD6F26E  ELEMENT_mp_LOCALM       20494  datatype.f90
fem.exe            000000013FDE82ED  ELEMENT_mp_TESTME       20389  datatype.f90
fem.exe            000000013FF1DFEF  LOGGING3D..0             4600  main.f90
fem.exe            000000013FEFE700  MAIN_PARALLEL             240  main.f90
fem.exe            000000013FE8C02D  MAIN__                     39  main.f90
fem.exe            00000001429799B6  Unknown               Unknown  Unknown
fem.exe            0000000140950D88  Unknown               Unknown  Unknown
kernel32.dll       000000007775652D  Unknown               Unknown  Unknown
ntdll.dll          000000007798C541  Unknown               Unknown  Unknown
where fem.exe is the Fortran main program and CSGlib.dll is the C++ dynamic linked library. I can get to know the crash location of Fortran code but can't get to know the location of C++ code.
What do I miss in project settings?
original post is here:
https://software.intel.com/en-us/forums/topic/517867
Zhanghong Tang
Zhanghong_T_
Progress: I tried to check the PDB files generated by the command
DUMPBIN /HEADERS fem.pdb
and
DUMPBIN /HEADERS csglib.pdb
The following errors displayed:
Microsoft (R) COFF/PE Dumper Version 11.00.61030.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file fem.pdb
fem.pdb : warning LNK4048: Invalid format file; ignored
  Summary
Dump of file csglib.pdb
csglib.pdb : warning LNK4048: Invalid format file; ignored
  Summary
What settings should I add to generate valid format files?
IanH
Dumpbin (as far as I am aware) does not read PDB files - hence the errors you see in your follow up post.
Try specifying the /traceback option for the C++ compiler when you build the DLL.  That, plus /Zi, should give a reasonably specific location.
Zhanghong_T_
Hi IanH,
Thank you very much for your kindly reply. I have already specified the options /traceback and /Zi, but the output message still didn't give the location that crash happened in C++ code.
Is there anything that I missed?
IanH
What other options are you using when you compile the DLL?
An example that works for me:
// crash-c.cpp
#include <cstdlib>
void c_two();
void c_three();
extern "C" void __declspec(dllexport) c_one()
  c_two();
void c_two()
  c_three();
void c_three()
  char *p = NULL;
  *p = 1;  // boom
! crash-fortran.f90
PROGRAM Crash
  IMPLICIT NONE
  CALL f_one
CONTAINS
  SUBROUTINE f_one()
    CALL f_two
  END SUBROUTINE f_one
  SUBROUTINE f_two()
    CALL f_three
  END SUBROUTINE f_two
  SUBROUTINE f_three()
    INTERFACE
      SUBROUTINE c_one() BIND(C,NAME='c_one')
        IMPLICIT NONE
      END SUBROUTINE c_one
    END INTERFACE
    CALL c_one
  END SUBROUTINE f_three
END PROGRAM Crash
>icl /LD /traceback /Zi "crash-c.cpp"
>ifort /traceback /Zi "crash-fortran.f90" "crash-c.lib"
>crash-fortran.exe
crash-c.dll        000007FEF6031040  ?c_three@@YAXXZ            19  crash-c.cpp
crash-c.dll        000007FEF6031024  ?c_two@@YAXXZ              13  crash-c.cpp
crash-c.dll        000007FEF603100F  c_one                       8  crash-c.cpp
crash-fortran.exe  000000013F4E1062  CRASH_ip_F_THREE           19  crash-fortran.f90
crash-fortran.exe  000000013F4E104D  CRASH_ip_F_TWO             10  crash-fortran.f90
crash-fortran.exe  000000013F4E1038  CRASH_ip_F_ONE              6  crash-fortran.f90
crash-fortran.exe  000000013F4E101E  MAIN__                      3  crash-fortran.f90
crash-fortran.exe  000000013F57EFCE  Unknown               Unknown  Unknown
crash-fortran.exe  000000013F556173  Unknown               Unknown  Unknown
kernel32.dll       00000000770559ED  Unknown               Unknown  Unknown
ntdll.dll          000000007718C541  Unknown               Unknown  Unknown
Zhanghong_T_
Dear IanH,
Instead of building program by command line, I created the project by VS2012. I attached a sample project which can reproduce my problem. Could you please help me to take a look at it?
Zhanghong Tang
Zhanghong_T_
Dear IanH,
I forgot to add /traceback option in project settings. Now I added this option and updated the project. It seems that Debug version is OK but Release version is still not correct located. Could you please help me to take a look at it?
pbkenned1
Hello Zhanghong,
Thanks for posting crashtest.zip.  Let me do some debugging, and I'll follow up here.  Since this seems more like a Fortran issue than C++ issue, I will close the original post https://software.intel.com/en-us/forums/topic/517867 on the C++ Forum.
Patrick
Zhanghong_T_
Dear Patrick,
Are there any wrong settings in my project?
Zhanghong_T_
Dear IanH,
How to build a x64 version DLL by command line?
I tried to test your example by
icl /LD /traceback /Zi /MACHINE:X64 "crash-c.cpp"
but the compiler displayed the following error:
icl: command line warning #10006: ignoring unknown option '/MACHINE:X64'
// crash-c.cpp
#include <cstdlib>
void c_two();
void c_three();
  c_two();
void c_two()
  c_three();
void c_three()
  char *p = NULL;
  *p = 1;  // boom
! crash-fortran.f90
PROGRAM Crash
  IMPLICIT NONE
  CALL f_one
CONTAINS
  SUBROUTINE f_one()
    CALL f_two
  SUBROUTINE f_two()
    CALL f_three
    INTERFACE
        IMPLICIT NONE
    END INTERFACE
    CALL c_one
END PROGRAM Crash
>crash-fortran.exe
mecej4
You need to use the proper command window (one which is configured to use IFort-x64), by choosing a command window shortcut with a name similar to "Intel 64 Visual Studio 2012 mode", under Intel Parallel Studio in the program menu.
Within that window, IanH's commands will work fine. You used the incorrect option /MACHINE:X64 in your command line. First of all, that is an option to the librarian (LIB) and linker (LINK) commands, not the compiler. Secondly, if you use the proper command window, this option is unnecessary.
jimdempseyatthecove
I do not know if this is pertinent or not.
When building a Release build from Visual Studio .AND. adding compiler options for debug line numbers (and likely traceback) the compiler will produce that information.
However, the Link options for Release build default to strip off all debug information.
In VS Solution property page for Linker, Debugging, set Generate Debug Info to Yes (/DEBUG)
Jim Dempsey
Zhanghong_T_
Dear mecej4,
I have already used that window, but the built DLL of my own program is wrong. I don't know why...
Zhanghong_T_
Dear Jim,
Thank you very much for your kindly reply. I have already set that option as you said, but it seems that only Debug version shows the error information correctly.
Jim Dempsey
pbkenned1
Hello Zhanghong,
You said "only Debug version shows the error information correctly."  Do you get any error information?  When I build in Release mode, then do Debug > Start Debugging, I get trigger a breakpoint on  newtest->crashtest();   That's not quite what I expected, but I do get a traceback (see attached).
As an aside, for simple coding errors like divide-by-zero, you should just be using Debug mode to track them down.  It's can be much harder in Release mode, due to inlining, loop optimsations, etc.
Patrick
pbkenned1
Just to emphasize what I said in my last post, you can trigger a breakpoint in the Release build on the actual divide-by-zero by disabling inlining in the DLL (Properties > C/C++ > Optimization > Inline Function Expansion > Disabled (/Ob0).
Patrick
Zhanghong_T_
Dear Patrick,
I just use the divide-by-zero to reproduce the crash problem and show that the crash problem can't be located in Release mode. I don't know what and where the crash problem is in my real code (the crash only happens in Release mode).
The option /Ob0 has successfully located the crash lines, but it still can't locate the crash location in my real program.
On the other hand, I also tried to test the command line by IanH, it can also locate the crash lines for the example without the option /Ob0.
Zhanghong_T_
Dear Patrick and Jim,
I also tried to build my own project in command line as follows:
icl /D "TETLIBRARY" /D "CARVE_USE_EXACT_PREDICATES" /D "CARVE_SYSTEM_BOOST" /D "CARVE" /D "WIN64" /D "NDEBUG" /D "_WINDOWS" /I".\CSGlib\mesh" /I".\CSGlib\mesh\include" /I"C:\Program Files (x86)\boost_1_54_0" /I"C:\Program Files (x86)\Intel\VTune Amplifier XE 2013\include" ".\CSGlib\*.cpp" ".\CSGlib\mesh\*.cxx" ".\CSGlib\mesh\lib\*.cpp" ".\CSGlib\mesh\common\*.cpp" ".\CSGlib\mesh\external\src\*.cpp" /LD /bigobj /traceback /fp:precise /Zc:wchar_t /Zi /O2 /MT /EHsc /Fo.\obj\ /Fe:"Z:\directional\for_debug\CSGlib.dll" /Fd:"Z:\directional\for_debug\CSGlib.pdb" /F10000000000
After successfully built, I run the executable (still built from VS2012 IDE), the following error message displayed:
fem.exe - Application Error
The application was unable to start correctly (0x000007b). Click OK to close the application.
Is there any missed options I have not added?
Lorri_M_Intel
Try cutting back the pre-allocation size of the stack:
change /F10000000000  to something a bit smaller, and see if your executable will start up.
Zhanghong_T_
Dear Lorri,
Thank you very much for your kindly reply. I also noticed that and I changed it to /F1000000000, the problem is solved.
Currently I can locate the problem by running my real program built from command line.
