29542 讨论
How to pass a dynamic structure from vb.net to Fortran DLL
Goicochea__Javier
初学者
1,146 次查看
I am having trouble passing structures or classes from vb.net to my Fortran DLL. In particular I would like to pass a structure or class which dynamic members (i.e. 1D arrays with dynamic memory allocation). I actually can pass fixed-size arrays but not dynamic ones.
Below is a working example of what I am trying to achieve (the dynamic part is not working). So basically in the vb.net code there is a simple DynStructure that contains an integer and a 1d dynamic integer array. Below is the corresponding fixed-length counterpart (StaStructure). When sub1 is called, the subroutine passes to the DLL (no error) but no access to array members is possible. Under Visual Studio the "dynArr" array is marked as "undefined pointer/array". When sub2 is called everything works well, but the array has a fixed length.
Thank you in advance for your help!
*** VB:NET ***
Imports System.Runtime.InteropServices
Module Intel
    <DllImport("C:\Users\goicochea_j\Documents\03_vb.NET\19_NetPpkg\NetPpkgDll1\PpkgDll\Debug\PpkgDll.dll", CallingConvention:=CallingConvention.StdCall)> _
    Function sub1(ByRef dS As DynStructure) As Double
    End Function
    Function sub2(ByRef dS As StaStructure) As Double
    End Function
    <StructLayout(LayoutKind.Sequential)>
    Structure DynStructure
        Dim id As Integer
        Dim dynArr() As Integer
    End Structure
    Structure StaStructure
        Dim id As Integer
        <MarshalAs(UnmanagedType.ByValArray, SizeConst:=3)> Dim staArr() As Integer
        Sub New(ByRef n As Integer)
            ReDim staArr(n - 1)
        End Sub
    End Structure
    Sub Main()
        Dim dS As DynStructure
        dS.id = 123
        dS.dynArr = {1, 2, 3}
        ' Call to Fortran DLL
        'sub1(dS)
        Dim sS As StaStructure = New StaStructure(3)
        sS.id = 123
        sS.staArr(0) = 3
        sS.staArr(1) = 2
        sS.staArr(2) = 1
        sub2(sS)
    End Sub
End Module
*** Fortran ***
module mod_Intel
   type DynStructure
      integer              :: id
      integer, allocatable :: dynArr(:)
   end type DynStructure
   type StaStructure
      integer              :: id
      integer              :: staArr(3)
   end type StaStructure
   contains
   subroutine sub1(dS)
      type(DynStructure), intent(inout)   :: dS
      integer                             :: i
      !DEC$ ATTRIBUTES DLLEXPORT    :: sub1
      !DEC$ATTRIBUTES STDCALL       :: sub1
      !DEC$ATTRIBUTES ALIAS         : 'sub1' :: sub1
      !DEC$ ATTRIBUTES REFERENCE    :: dS
      ! Change id
      dS%id = 321
      ! Modify dynamic array
      do i = 1, size(dS%dynArr)
         dS%dynArr(i) = i
      end do
   end subroutine sub1
   subroutine sub2(sS)
      type(StaStructure), intent(inout)   :: sS
      integer                             :: i
      !DEC$ ATTRIBUTES DLLEXPORT    :: sub2
      !DEC$ATTRIBUTES STDCALL       :: sub2
      !DEC$ATTRIBUTES ALIAS         : 'sub2' :: sub2
      !DEC$ ATTRIBUTES REFERENCE    :: sS
      ! Change id
      sS%id = 321
      do i = 1, size(sS%staArr)
         sS%staArr(i) = i
      end do
   end subroutine sub2
end module mod_Intel
0 项奖励
2 回复数
Amalia_B_
初学者
1,146 次查看
This is an old post - I'm looking to do the same thing, but haven't seen any responses.  Has anyone figured out how to do this?
0 项奖励
1,146 次查看
This is almost certainly not possible without knowing the internals of how VB constructs such structures. You can probably pass individual components, however.
0 项奖励
回复
